In order to engrave and profile 1.5 mm thick aluminum sheet I tried holding it with screws to plywood base, with double stick tape to a sacrificial aluminum plate and of course with small clamps. Nothing works and in most cases (apart from the double stick tape) the sheet gets a small bend from the pressure of whatever holds it and I get uneven cuts.
Any idea what would be the best way to hold different sizes of thin aluminum or metal sheets for milling work?
Thanks!
