587,316 active members*
3,483 visitors online*
    May 2011
    29
    holding tolerance
    trying to machine a hole with +/- .001 around 11.700 long. having trouble with it being to big at top and bottom for the first .5 to 1.0 deep. tried more spring passes and adjusting wire tension and pretension. We are have a Mitsubishi FA20S.
    Aug 2008
    406
    If you know which way it is tapering use your u,v axis to cut taper oppsite of what you are getting to compensate . I find the taper in long holes is caused buy the the eroded wire passing throught the burn run wire speed as fast as possible on finishing .
    May 2011
    29
    thanks but done a little more research and found that i need to slow down feedrate on 1st skim and increase my voltage gap to cut more material out of middle of part. I am now able to hold with in .0003 from top to bottom.
  1. 1/4-20 Tap Tolerance
    By xander18 in forum MetalWork Discussion
    Last Post: 10-04-2011, 10:14 PM
  2. Trouble holding tolerance
    By RickP in forum MetalWork Discussion
    Last Post: 06-30-2009, 11:31 PM
  3. ISO Tolerance Help?
    By Billet Sean in forum MetalWork Discussion
    Last Post: 06-18-2008, 01:04 AM
  4. Q: Tolerance - How much is to much?
    By Deviant in forum Mechanical Calculations/Engineering Design
    Last Post: 03-28-2007, 09:23 PM
  5. tolerance
    By heilcnc in forum Benchtop Machines
    Last Post: 04-29-2006, 02:31 PM
