588,616 active members*
6,120 visitors online*
Thread: Holes?
    Holes?
    I almost have this demo figured out! My only problem now is the automatic finding of holes. I have some small patterns that I'm cutting that have tiny enclosed areas that aren't really holes and I don't want them drilled/milled, but Sheetcam is finding them and attempting to drill them. I've messed with the hole settings, but can't get Sheetcam to stop finding and milling them out. Mind you, these are small - a 1/16" mill, if plunged like Sheetcam wants, will destroy the pattern.
    Is there a way to tell Sheetcam to ignore these holes?
    Thanks!
    Mark
    Mar 2003
    35538
    Can you put them on a different layer and do it that way? I haven't used SheetCAM since the early betas, so I can't be more specific.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Quote Originally Posted by ger21
    Yup - that did it! I didn't even think about a new layer strategy, but that worked perfectly!
    Thanks,
    Mark
