588,556 active members*
4,512 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Sep 2006
    218
    Home build CNC mill/router
    What do you think about this machine?
    It took me about 3 weeks to build-it from scratch, but the results are very good. Cnczone was very usefull.
    Things left to be done:
    - arrange the wires
    - mount limit switch and Estop
    - update to a 3 axis microstepp driver (i would like to use the new A4983 allegro chips)
    - buy a USB CNC controller
    - build an automatic speed controler for motor (it is a cheap 220V/115W driller, but is working very well in DC too - so it's easy to control the motor voltage to get different RPM; tought about encoder-PIC-pwm-PowerMOS to set the speed)
    You will see the tools i have been used, and the result (2 pcb)
    Attached Thumbnails Attached Thumbnails image019_2.jpg   Image020_2.jpg   Image021_2.jpg   Image022_2.jpg
    Dec 2006
    532
    Machine is looking pretty good, what are working dimensions?
    Is there reason why you want to use USB?
    Sep 2006
    218
    Quote Originally Posted by rustamd View Post
    30/30/8 cm (forget to mention)
    i want to use my notebook;
    usb will be much smother as parallel port;
    i do'nt want dos mode for a computer.
    Sep 2006
    218
    evolution
    arranged the wires, and maked a small project:
    a Nokia 3310/3410 display to be used with my 16FXXX
    all made with my cnc (except display, ofcorse )
    Attached Thumbnails Attached Thumbnails Image017.jpg   Image018.jpg   Image020.jpg   Image022.jpg
    Mar 2008
    3
    please anyone has adocumentation about
    using USB with pic microcontroller?
    Nov 2007
    11
    I LIKE IT
    Aug 2005
    578
    http://www.create.ucsb.edu/~dano/CUI/
    Bob
    Jul 2007
    165
    Have you got any pics of the anti-backlash configuration you have mentioned? Would be interested to see this, since I have much the same leadscrews and leadnuts.
    Sep 2006
    218
    My new mini-CNC mill for PCB
    Hello,
    This time took me about 1 week to complete the mechanical part of this. I wanted to be cheap... very cheap, and with components that can be found in any hardware store.
    Used:
    - drawer sliders;
    - Al frame - square;
    - Al frame L shape, 2mm/3mm thick
    - some Al sheet (2-3mm thick);
    - blind rivets;
    - M4 nuts and bolts;
    - M8 acme thread;
    - hard plastic as M8 nut;
    - aquarium tube;
    - steppers
    - MDF 30x30 cm
    Tested only one axis at time, with manual jog, and seem to work properly. Backlash is zero at the moment - but probably will appear soon. Seem stiff enough - more than enough to mill and cut PCB.
    After I finish the electronics part, I will test-it more.
    Thanks for watching and sharing your opinion
    Attached Thumbnails Attached Thumbnails DSC01164.jpg   DSC01165.jpg   DSC01151.jpg   DSC01140.jpg
    Apr 2005
    7
    The first machine at the top of the page , what kind of tubing and bearing setup is that and where did you get it from.
    Sep 2006
    218
    Quote Originally Posted by GLynnC View Post
    There are 12mm round rod with associated bronze bushings. I get them from A3 XEROX inkjet printer (don't remember the model). Steppers are from that printer too.
    Nov 2009
    115
    it looks nice
    Aug 2009
    392
    Very nice looking machines.
    Apr 2005
    7
    Quote Originally Posted by eSilviu View Post
    Very interesting , thanks for the reply.
    Sep 2006
    218
    more pictures
    Hello,
    I've started with the idea of building a PCB mill with 10x16cm working area (Eagle light limitation, more than enough for 90% of my PCB's).
    I've ended with a mill with 15x21cm working area, and 7cm of Z travel.
    Working good until now: attached a sacrifice MDF, and leveled the working area.
    Pictures represent:
    - whole mechanical CNC
    - nut-spring-nut used for Y axis
    - controller + manual jog + bipolar drivers for steppers
    (controller = CNCUSBController from Kroko)
    - stepper drivers = A3979 based, and are working amazing from a 12V power supply
    - RC outrunner used as spindle for milling PCB's (has 3.17mm inner bearing diameter ), well.. milling PCB’s needs only about 15W of power!!!
    - 2x12V,2.5A power supply - one for controller and one for spindle
    - I intend to put all electronics part on the back of machine
    - a small PCB milled just for test (the one with larger isolation tracks was obtained by running the same g-code for about 15 times, just to see what will happen); note: there is no software compensation for backlash!
    Merry Christmas to you all!
    Attached Thumbnails Attached Thumbnails DSC01257.jpg   DSC01258.jpg   DSC01259.jpg   DSC01261.jpg
    Aug 2009
    392
    Looks great! Get those electronics organized and you're good to go
  17. #17
    Sep 2009
    9
    Looks great guess I will have to start on one here shortly. Love all these post with very positive results. I have a dremel and a sears 1/4" router and will use those as proto types. if all works good then I would start a search for the famous porter cable 1/2".
  18. #18
    Sep 2006
    218
    Wink
    this is how I've started..
    it was the first attempt to do a cnc.
    alltrough it wasn't any real use, it helped me to understand all weak points of the design, and to find better solutions.
  19. #19
    Jan 2009
    57
    Out runner motor
    What are you using to control the spindle motor?
  20. #20
    Aug 2009
    392
    Seeing as he's using an RC Outrunner motor, I'd assume he's simply using an ESC, and feeding it a PWM signal from some source. I'm sure he'll let us know though
Page 1 of 2 12
  1. Home Shop: Mill, Router or both?
    By biomed_eng in forum Polls
    Last Post: 08-11-2015, 02:56 PM
  2. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
  3. home built cnc router
    By sanjiv in forum DIY CNC Router Table Machines
    Last Post: 08-17-2006, 09:43 AM
  4. Another home built router :)
    By steveald in forum DIY CNC Router Table Machines
    Last Post: 03-19-2005, 07:22 PM
  5. purchase or building a home cnc router.
    By s_bedow in forum DIY CNC Router Table Machines
    Last Post: 03-19-2005, 07:22 AM
