587,143 active members*
3,390 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Home made Drum Sander
Page 12 of 14 21011121314
Results 221 to 240 of 278
  1. #221
    Jul 2010
    1328
    Quote Originally Posted by adprinter View Post
    Mark,
    I posted before seeing this drawing (after modifying my original drawing). I can see now, what you are talking about. I apologize for not being able to visualize what you were designing. I did not realize that you would be going ABOVE the table's surface. In my design, everything happens BELOW the table's surface. Six of one, half-dozen of the other- I suppose.
    I'm not actually going above the table... That plate is on the bottom of the feedbelt assy... The feed belt assembly is about 7" tall... But I 'am' mounting all of the gears and what not to the stationary frame, and using the ACME Nut to 'push up' against the feedbelt table.... All the top HPDE blocks do is hold the screws vertical...
  2. #222
    Jul 2010
    1328
    These pictures are of the feedbelt assembly.. The whole thing will raise and lower within the stationary frame... The 5/16" thick plate welded to the bottom of the unistrut (with the blue machinists dye on it), is the "feedbelt frame" in my illustration a couple posts back...
    The ACME nut will be floating underneath the 5/16" steel plate...
  3. #223
    Feb 2011
    270
    Quote Originally Posted by Mountaincraft View Post
    A graphic illustration of WHY a picture is worth a thousand words! Very nice build you've got going there. And (between the graphic you posted a couple of posts ago) and the photos of the table, I don't see any reason why your design wouldn't work like a charm!
  4. #224
    Jul 2010
    1328
    So after a minor nightmare with damaged shipment then duplicate orders, etc.. My ACME screw, sprockets, and idlers should arrive this afternoon... All of the sprockets and idlers are for #40 1/2" pitch chain... Trying to order some chain off of ebay, but they are using slightly different terminology...
    Is #40 - 1R industrial roller chain the right choice for #40 - 1/2" pitch sprockets ordered from McMaster Carr? Or is there more than one configuration of #40 chain?..
    Gracias,
    Mark
  5. #225
    Sep 2011
    1183
    Mark looks good your coming right along with your build..
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  6. #226
    Feb 2011
    270
    Gracias,
    Mark
    I am not familiar with industrial standards for roller chains/sprockets. But a search on the internet should find several links for obtaining the information. Sorry that I don't have the information at hand. Perhaps a search for roller chain manufacturer's would help you to find engineering drawings for the #40 chain (which you could probably use to help identify the correct sprockets to be used with the chain).
  7. #227
    Feb 2012
    Gave me an idea this to replicate the construction for a metal grinder or finisher,but with only a wide grinder wheel in the center.
    The grinder could be for getting the metal shiny or levelling sides of a box sectionioned frame thats just been welded?
    This is the wheel I'm on about....
    http://onewayeuropa.com/sharpening/i...eels_450px.jpg
  8. #228
    Jul 2010
    1328
    Quote Originally Posted by HorridHenry View Post
    Might work, but I would think it would have different motor speed and HP requirements... I'd also wonder about uneven wear, and how to keep it continually dressed...
  9. #229
    Jul 2010
    1328
    More Progress...
    Worked on this over the last two days.. Lot's of cutting, drilling, grinding, welding, grinding, cutting, welding, drilling, repairing threads,etc... Woke up this morning feeling like a truck hit me.. LOL
    Anyways, the bottom end (the hard part) is almost finished... I need to add a couple links to the chain, adjust everything and tack the lead screw nuts in place.. Need to make the lead screw positioners on top.. either out of hardwood or cutting board... Will probably design them tonight and cut them on the CNC tomorrow... Then I need to either buy or make a hand wheel crank for the lift...
    Beyond that, it's a matter of talking to tech support at a couple sanding belt suppliers to get some input, and then taking the feedbelt shafts to a local machinist to have them shaped so that the belt doesn't walk... Then the top end should go a lot faster... Still need to come up with a drive system for the belt, but if I have to I might just make a hand crank for now to feed material with ....
    I'm gonna need to buy a second V belt as the one I bought isn't gonna be long enough.. fortunately, I can use a second belt to make it exactly the length I need...
    Very pleased with the amount of force needed to crank the thing... Gonna get even easier once I get everything adjusted and lubricated...
    Anyways, it's a beast... But it's much closer to being a 'living/breathing' beast than is was a couple days ago...
  10. #230
    Aug 2011
    617
    What an interesting contraption you have there!
    I hope it works as good as it looks
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
  11. #231
    Sep 2011
    1183
    Mark you have put a lot of work into it can't wait to see it running...
    Lou:wave:
  12. #232
    Jul 2010
    1328
    Quote Originally Posted by TrickyCNC View Post
    LOL.. Not half as much as I do!
    As long as I can get the feedbelt itself to track properly, it's all downhill now...
  13. #233
    Jul 2010
    1328
    Quote Originally Posted by LouF View Post
    Lou:wave:
    Me too.. I'm sick of using my palm sander!
  14. #234
    Apr 2007
    8082
    That's looking like a real engineering project. Hoping the project turns out to be better than you expected. My DeWalt 12" planer has a chain drive lift mechanism. It works very well.
    CarveOne
    http://www.carveonecncwoodcraft.com
  15. #235
    Feb 2011
    270
    More Progress...
    I can relate. I've been working the past four days on extending the X axis on my CNC. Basically, (yet AGAIN) doing a complete disassembly, redesign, and reassembly of the entire machine! Same here, cutting, grinding, welding, drilling, tapping, and I haven't even started on the electrical side yet.
    Did you get the tag number of that truck? -I think it passed through McDonough!
  16. #236
    Feb 2012
    Oh wow,you're going to have some fun aligning that chain on each sprocket ain't cha,I mean one sprocket only has to be 1 thread out and its gonna drift the adjoining sprocket/s
  17. #237
    Jul 2010
    1328
    I figured it out, and one sprocket equals .0067 inch of vertical travel, and then that is spread across a minimum of 25" which comes out to .00027" per inch... Add to that that the drum mount on the top end will also be adjustable, and everything is fine tunable with an end wrench or allen wrench...
    Furthermore, simply loosening a pair of setscrews on the sprocket and turning the acme screw allows for adjustment without removing the chain to jump a tooth...
    If I can get to where I'm precision sanding to the point where 6 thousands across 25" is a problem, I'll be pretty dang excited (How consistent is sandpaper anyways?)... Heck from what I can see, the wood itself changes more than that just between day and night temps... There always seems to be at least a little warping, cupping, twisting going on with temp and humidity changes even with thoroughly dried and planed wood...
    They use a very similar method on surface planers....
    I'm quite sure that as long as I get the belt tracking issue resolved, I'll be very happy with this things performance for it's intended purposes.. I will have saved a few hundred (or more) dollars over buying one, and it will have custom features included that are simply not available on any retail sander I have seen..
    So, one of the two issues I was concerned about has been addressed (how much rotary force was required to lift and lower the table) and has exceeded my expectations, and one remains (belt tracking)..
    After that it's all downhill... The top end should be pretty straight forward.. I have pretty much all the materials I need for that already.. And having the CNC to precision cut the parts should make it all go fairly smoothly...
    The only remaining design issue I even see is how to extract dust most efficiently without having the fittings in the way and still allow for the quick change drums...... But even that is starting to get nailed down in my head...
  18. #238
    Sep 2011
    1183
    Mark, now I know what happen the chain from my old Indian...:stickpoke
    Lou
  19. #239
    Jul 2010
    1328
    So, I've designed the lead screw bushings to hold the top end of the lead screws in place..
    material around the bushing hole at the end has to be pretty thin.. (.2")... So MDF/hardwood is out..
    Worst case, I'll go with aluminum, but I've never machined it yet and really don't want to use any of the scrap I've been accumulating to make gantry supports/transitions for my CNC rig from...
    So I looked on line and it seems that Delrin is the hot ticket.. But man, that stuff is pricey... More than aluminum... I don't expect a 'lot' of force to be applied against that edge as most force will be along the sides where I have room to make thicker...
    So my question is, how much difference is there between HDPE and Delrin in as far as strength, compression/stretch, wearability (bearing surface), and machinability?
    Is it worth wasting my money on a couple cutting boards, or should I bite the bullet on Delrin, Aluminum, or???
    For reference, the red part shows a small pocket that will cradle the top of the 1.5" steel tube, while the slot is where a 3/8" bolt and nut will allow adjustability along the length of the steel tube... The round hole is where the 1/2" ACME screw will pass through... The purpose of these bushing blocks is to simply hold the screws vertical..
  20. #240
    Aug 2011
    617
    Size for Size, I've found Delrin to be cheaper than Ally
    I bought a block 4" x 4" x 2" for £4 GBP off of e-bay
    Oh, and I have been noticing that a certain poster doesn't have much nice to say about anyones efforts, so I'd take it with a pinch of salt If you think about the alignment of a chain on a pedal bike ... it's not very accurate at all !
    Keep up the good work
    Rich
  1. Another DIY drum sander build
    By CarveOne in forum WoodWorking Topics
    Last Post: 01-11-2015, 04:19 AM
  2. New Project - building a drum sander
    By Hack in forum WoodWorking Topics
    Last Post: 09-04-2011, 01:38 AM
  3. Drum Sander Plans Available
    By Hack in forum News Announcements
    Last Post: 09-17-2005, 09:19 PM
