603,843 active members*
4,911 visitors online*
Results 1 to 7 of 7
    Mar 2003
    6855
    Home is not working
    I click the home button and nothing happens, no matter what settings I use I can get the machine to home. Mind you that all worked before I upgraded the deskcnc software. Any ides?
    Mar 2004
    564
    what if you wiped it all out and re-loaded the software? perhaps a file got corupted during the up-grade? or perhaps you have a conflict with the resources in your device manager?
    menomana
    Mar 2003
    35494
    Did some of your home switch setting get reset?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2004
    80
    I had the same problem, its not your hardware . The newer versions ( last two) have the provisions for homing scripts . You need to go to the machine setup tab- homing scripts. there you give the command of G30 X1Y2Z3 where X1Y2Z3 are the offsets from home position for each axis.
    Try using just the g30 to begin with.
    Hope this helps
    Mar 2003
    6855
    You have to use homing scripts?
    Mar 2003
    6855
    one thing I didn't do is overwrite any of my profiles.
    Oct 2004
    80
    That is a different issue altogether. Your machine profile , it seems wouldnt contain any info on how to home. I had written to deskcnc and this is what i had been told.
    Since I wasnt comfortable with doing scripts etc.. I still am using the older version on my machine until i can work things out with the script.
  1. Limit and home switches EMC and Mach2?
    By ESjaavik in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2008, 04:39 PM
  2. How do you hook up limit and home switches?
    By cncadmin in forum DeskCNC Controller Board
    Last Post: 09-23-2007, 09:34 PM
  3. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  4. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  5. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
