New guy to the forum and first cnc machine build . Just starting frame work . Should be 24x36 with 12" Z travels . Should have welding done soon so it can go for heat treatment
.750 steel ribs and plate for gantry mount
3x5 .375 wall rails
Gantry tubing is 6x10 .5 wall tubing
Have 2505 ball screws with double nuts for all axis
25mm linear rails for all axis
DMM 750w ac servos and drives all here .
Purchased the controller form CNC4PC , its on the way . Using a UC300ETH board all set up to go in an enclosure form Arturo .
Have not totally decided on a spindle but eyeing a 5.5KW BT30 atc spindle
More to come as progress is made .
DaveAttachment 436274Attachment 436276Attachment 436278Attachment 436280
