603,344 active members*
3,639 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > Homemade Mini Lathe Aluminium Alloy with Slide CNC Linear Ball Bearing Motion Bearing
Results 1 to 5 of 5
    May 2015
    67
    Angry Homemade Mini Lathe Aluminium Alloy with Slide CNC Linear Ball Bearing Motion Bearing
    Parts and Tools:
    Wood MDF 200 mm x 650 mm x 20 mm
    2pcs SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
    2pcs 500 mm 20 mm Linear Rails
    1 Pcs 530 mm x 140 mm x 12 mm Aluminium Alloy 6061
    2 Pcs 60 mm x 140 mm x 12 mm Aluminium Alloy 6061
    2 Pcs 80 mm x 120 mm x 12 mm Aluminium Alloy 6061
    1 Pcs 80 mm x 140 mm x 12 mm Aluminium Alloy 6061
    1 Pcs 80 mm x 110 mm x 62 mm Aluminium Alloy 6061
    1 Pcs 12 mm x 140 mm x 12 mm Aluminium Alloy 6061
    Lathe Chuck 80 mm 2 pcs, Head Chuk Drill,
    May 2015
    67
    Re: Homemade Mini Lathe Aluminium Alloy with Slide CNC Linear Ball Bearing Motion Bea
    May 2015
    67
    May 2015
    67
    May 2015
    67
  1. Homemade mini Lathe by Aluminium Alloy
    By doitbymyhand in forum Wood Lathes / Mills
    Last Post: 06-11-2015, 10:11 AM
  2. Replies: 4
    Last Post: 05-17-2015, 10:02 AM
  3. T-Slot Delrin bearing slide for linear motion on DIY CNC?
    By telmnstr in forum Linear and Rotary Motion
    Last Post: 02-15-2015, 01:19 PM
  4. Linear Slide/Bearing guards
    By alevitt53 in forum Want To Buy...Need help!
    Last Post: 01-23-2013, 08:34 PM
  5. Wich Length of Linear Bearing Slide
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 01-21-2012, 12:10 AM
