603,316 active members*
2,489 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > Homemade Mini Milling Mill Router Machine with Slide Axis CNC
Results 1 to 5 of 5
    May 2015
    67
    Angry Homemade Mini Milling Mill Router Machine with Slide Axis CNC
    Parts and Tools:
    4 or 6 or 8 SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
    2 x 300 mm 20 mm Linear Rails
    2 x 400 mm 20 mm Linear Rails
    Aluminium Alloy 6061 400 mm x 160 mm x 12 mm.
    Aluminium Alloy 6061 62 mm x 250 mm x 12 mm
    Linear shaft 25 mm x 600 mm aixs
    Linear shaft 11 mm x 300 mm aixs
    1 pcs SHF25 25mm Linear Rail Shaft Support XYZ Table
    1 pcs 25mm LINEAR BALL BEARING CNC
    May 2015
    67
    Re: Homemade Mini Milling Mill Router Machine with Slide Axis CNC
    May 2015
    67
    May 2015
    67
    Apr 2004
    5948
    I don't see that design being rigid enough for routing, although it might work as a drill. That single thin rod that supports the Z axis is the main problem. Replace that with something a lot stouter, and better anchored to the base, and you might have a chance, although all those unsupported rods in the X and Y axes will still be limiting factors.
    Andrew Werby
    Website
  1. Replies: 4
    Last Post: 05-17-2015, 10:02 AM
  2. Milling Steel with a homemade router - help
    By harisfifo in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2011, 09:39 AM
  3. Help with Y slide on HF Mini Mill
    By wdp67 in forum Benchtop Machines
    Last Post: 12-16-2007, 06:32 AM
  4. Homemade mini-mill
    By Parameter in forum Benchtop Machines
    Last Post: 08-16-2006, 04:53 PM
