I have been drilling and tapping lots of holes in case hardened linear rails, so I decided to make a clamp to go on my Bridgeport's quill to hold two Snap-Lok coolant lines!
I started with a chunk of 1018 CRS around 6x6x5/8.
First I sawed off the excess from one side, then I squared it up in the vise using my shell mill, and an endmill.
Then I picked center using an edge finder, and spot drilled all the hole locations. then I rough drilled all the holes.
NOTE: If you choose to make one of these, make the large bore match the quill on your machine!
