603,916 active members*
2,466 visitors online*
Results 1 to 5 of 5
    Jan 2005
    72
    Homing the 4th Rotary Axis "A"
    My 4th Axis which is the A rotary, is now operational.
    Given that the DeskCNC controller board allows for an "A" home input, I have provided it with an optical Omron switch to set Home on it. This will be very usefull to position my camshafts correctly.
    However, now, I can't find out how to home it from the DeskCNC control screen. Any prompt advise would be appreciated.
    Thanks,
    Daniel.
    Jan 2005
    72
    I guess there is no button for Homing in DeskCNC screen.
    However I managed to do it as a G code instruction in the MDI field
    G30 A xx Fxx
    Apr 2006
    101
    Keep up the good work
    Para
    I looked at the post about cams and was disappointed that everyone was so negative. I beleive that you can make your own cam machiine and learn along the way. You have the "what it takes" and "get 'er done" attitude that is really what cnczone is all about, not naysayers....
    "Nothing in the world can take the place of persistence"
    best regards,
    Barry
    my projects:
    http://www.barryfish.com
    Jan 2005
    72
    Thanks for the supporting words.
    Barry,
    thanks for your suportive posting.
    AS of now I have not implemented the setup but I have made most of the components required.
    My main difficulty is to convert digitized cam lobe data into Gcode.
    To digitize, I am using Performancetrends.com's cam tester setup.
    Daniel.
    Apr 2006
    101
    g code generation
    What form is the data in?
    It should be "relatively" easy to get it into a format where a small program could generate the g code.
    Or am I missing something?
    Also to get rid of the steps that "that negative guy" was complaining about you could likely use a program that supported beizer splines and smoothing.
    You are just going to spin the A axis and run you grinder with the Z, correct?
    To me the "impossible" part will be keeping the wheel accurate.
    I'm guessing that you will have to do 1 or more roughing grinds, then the final machining.
    (PS I'm not a grinder, just a do-er)
    "From the confidence that comes from ignorance, I proceed"
    best regards,
    Barry
    PS on the good side, as the wheel wears, your cam will err on the over size side, which it seems would be better that being undersized. ("but I'm not a grinder")
    my projects:
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  3. Has anyone looked at the "JET" or "Shop Fox" manual machines?
    By boosted in forum Uncategorised MetalWorking Machines
    Last Post: 03-05-2007, 04:33 AM
  4. Calculating "steps per unit" for rotary axis?
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2004, 10:31 PM
