587,303 active members*
3,542 visitors online*
Thread: Homing Issue
Results 1 to 4 of 4
    Jun 2004
    258
    Homing Issue
    Hope someone can shed some light on this.
    I have my manual tool change position at X0,Y0,Z120 machine moves to position correctly.
    After that I hit Alt H for home position which is X1000,Y200,Z100. What happens is that the Z then moves to Zero whilst the X and Y travel to their home positions and then Z lifts to Z100 (home) problem is the Z travelling down to Z0 first as it then drags the tool accross the table.
    How do I tell Mach to stay above the table at a safe height???.. what setting do I need to change?
    Moondog
    Mar 2003
    35538
    On the Settings screen, set Safe Z to the height you want. Then, under Config>Logic, check the box that says "Use Safe Z".
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2004
    258
    Thanks Gerry.. much appreciated...
    maybe you can help with this...
    At the end of my NC file I want to tell it to 'go home' which is x1000, y200, z100... tried to use M28 & M30 to no avail???
    also want to be able to pause program, go to tool change position... can't find the appropriate codes for Pause & Go to Tool Change Position. any ideas...
    manual tool change of course.
    Moondog.
    Mar 2003
    35538
    G0 Z100
    G0 X1000 Y200
    You should be able to add those lines in your post processor. I'm guessing you don't have home switches at those positions.
    Try going to www.machsupport.com and watch the tool changing video. It might get you going in the right direction, but I think it's for an ATC. I may be wrong, though. Check it out and see.
    Gerry
