588,208 active members*
4,896 visitors online*
Results 1 to 6 of 6
Hybrid View
    Apr 2006
    9
    Homing Problem V4.0.1
    When homing all the axes the Z and X axes start to home simultaneously. The Y axes waits. When the Z and X axes reach the home position the Y axes starts to home. All three axes have homing switches that are active low. I have used a logic probe to check the state of the homing switches and they are correct. (Pins 10, 11 and 12 )
    It is my understanding that all three axes must home simultaneously. I have check all the software settings and can not work out why the Y axes waits for the Z and X axes before homing.
    Mar 2004
    1806
    Does the Y axis finally home properly???
    You "may" have a problem with the setup depending on what bob you use. One of the pins on the parallel port is "inverted" (I think from memory it is pin 11). This caused me many headaches when I was setting up mine!
    I also notice you have a thread on backlash and this also messed up my homing setup. I had to turen backlash off in order to get things working. (solved the problem by eliminating the backlash and used ball screws)
    Art
    AKA Country Bubba (Older Than Dirt)
    Apr 2006
    9
    I have now changed the Logic on the inverted pin. The Z axes now homes first. Once the Z axes has homed. The X and Y axes start to home simultaneously. I think this is now the correct homing procedure.
    Apr 2006
    3
    Are you using the hobbycnc controller, if so re-check the pin settings the rev 1 instructions state the wrong pin allocations the new website has listed a new set of pins to use with rev 2 (dave has said they were both the same but there not).
    Apr 2003
    131
    Quote Originally Posted by chris tynan
    Sounds interesting to me as well. Can you beam your turbocnc.ini file to me at "[email protected]"?
    Apr 2006
    9
    No I built my own controller using UCN5804
