587,481 active members*
2,897 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Hooking Haas Mini Mill up to 220v wall socket verses direct wiring. Bad Idea?
    May 2013
    170
    I am a bit tight on space for my recently purchased Haas Super Mini mill, so I'm planning to mount a 220v wall socket and then just run a short cord from the machine that will plug into that socket ( verses running a direct line from my box direct to the machine )
    The reason I want to go this route is to have the option of easy disconnect in case I need to move the machine with a pallet jack from time to time in order to access the back panel. ( I am planning to place the machine fairly close to the wall )
    Any concerns of using a 220v socket verses direct wiring?
    Dec 2013
    5716
    Re: Hooking Haas Mini Mill up to 220v wall socket verses direct wiring. Bad Idea?
    None at all. Just make sure to use a plug/socket that is rated for at least the maximum machine amps.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2004
    6618
    I used an extension cord for my Mini Mill.
    https://www.amazon.com/Coleman-Cable...extension+cord
    Just cut one end off. It shares a receptacle with the plasma cutter so only one runs at a time. We only need the plasma a few hours a week.
    The mini mill is positioned like they suggest away from the wall in my shop, however that left us enough room to use a 2' x 4' Axiom Elite router between the Haas and the wall. It is on wheels though, so can just roll out when we need to access that panel.
    I would certainly mark the feet locations so that you can get them back as close as possible to original. That said, they may mark themselves with time.
    Lee
  1. Replies: 8
    Last Post: 12-21-2014, 01:49 PM
  2. Hooking up to 220v
    By zaebis in forum Tormach Personal CNC Mill
    Last Post: 11-29-2012, 04:32 PM
  3. belt drive verses direct
    By magnum500sw in forum Mechanical Calculations/Engineering Design
    Last Post: 05-14-2012, 11:19 PM
  4. mini-mill /bridgeport hybrid cnc idea, help
    By Sparky_NY in forum Benchtop Machines
    Last Post: 09-11-2007, 09:26 AM
  5. Direct drive vs. Belt Reduction - Mini Mill Conversion
    By sanddrag in forum Benchtop Machines
    Last Post: 02-10-2006, 05:00 PM
