603,785 active members*
17,624 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Hooking up the xylotex board
Results 1 to 7 of 7
    Dec 2003
    430
    Wow, this is not nearly as simple as everyone says it is, you must all be freakin geniuses. (genii??)
    I have e-mailed Xylotex for help, but I am hoping someone can point me in the right direction.
    I am running Mach2, on my 3 axis router. I have limit switches in series on one end of X and Y, and home switches wired individually on the other end of X and Y and on Z.
    I cant find anywhere where it says where on the board these get hooked up to. I have read everything I can find, and nowhere does it say where these can go.
    From what I understand, the board just routes these into the parallel connector, and then you configure in Mach2 what each signal means.
    Help me if you can,
    co
    Mar 2003
    35494
    There are 2 .pdf's on the Xylotex site that show possible limit switch connections. You might find it easier to use a secind parallel port and hook your switches to that.
    Gerry
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2003
    430
    Thanks. I found those PDF's last night after posting this. I understand how it works now. Still trying to figure out the e-stop though. Any advice there?
    co
    Apr 2003
    470
    A limit based E-stop would be wired as another limit only with the big bump switch.
    A proper e-Stop will cut the all power to the system by switching the AC power before the controller power supply.
    Nathan
    Dec 2003
    430
    So I can just hook up an NC pushbutton in series with the limits. Makes sense to me. Any idea where I can get a schematic for a real E-stop?
    co
    Nov 2003
    121
    try looking trough the balsamen tread where he builds the second router.That is the tread with most views on it 22000 I think.There are two schematics there, first one is incorrect. That is how I remember it.
    Dec 2003
    430
    Thanks everyone. I got it figured out. I am going to go with a limit based estop for now, with one home on each axis, wired individually, and a limit on the x and y and estop, wired in series.
    co
  1. Help with limit switches and Xylotex board
    By dowling177 in forum Xylotex
    Last Post: 11-26-2008, 09:51 PM
  2. Hooking up HobbyCNC board and motors to PC...
    By jdbaker in forum Hobbycnc (Products)
    Last Post: 06-06-2005, 07:10 PM
  3. Mill Post: MC9 to Mach2...I'm using a Xylotex Board?
    By EPM in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-21-2005, 03:05 AM
  4. Xylotex board and 214 oz motors
    By ljoe1969 in forum Xylotex
    Last Post: 09-01-2004, 12:21 AM
  5. MACH 2 configuration for Xylotex Board
    By ngr1 in forum Mach Software (ArtSoft software)
    Last Post: 08-13-2004, 07:03 AM
