587,597 active members*
3,788 visitors online*
Page 10 of 15 89101112
Results 181 to 200 of 290
  1. #181
    Aug 2006
    1602
    Yeah, servos are pricey, but having pretty decent torque all the way from 0-4000 rpm seems pretty special to me
    I am really impressed with the elegant simplicity of your ATC Hoss - every X2 should have one IMHO
  2. #182
    Jul 2003
    281
    Quote Originally Posted by digits View Post
    If you take a DC motor and add an Encoder to the motor , you have a servo.
    A while back I purchase a couple of DC motors for $10.00 and add a $35.00 Encoder, Total $45.00 for one.They sold out right quick before i could buy more. So look for the DC Motor Sales.
  3. #183
    Couple final ATC videos for now.
    These show how to set the tools in Mach 3 with Tool Offsets.
    Show it making the Z axis home switch cover.
    Hey, now I could start cranking the covers sets out to sell
    Check out parts A and B here.
    Later Hoss
    http://www.hossmachine.com
  4. #184
    Jul 2003
    281
    Quote Originally Posted by hoss2006 View Post
    Later Hoss
    Where did you get the Limit Swiches?
  5. #185
    Hey Bob,
    got the limit switches at my new favorite store, Surplus Center.
    They are wired in series with one wire going to your choice of input pin on the breakout board
    and the other to 5V.
    Check out 'Wiring Sample 1' at the bottom of the page at cnc4pc
    Later Hoss
  6. #186
    Aug 2007
    29
    Hoss,
    I've been to your website and tried to send you an email, but it keeps getting bounced, so this may be a little OT. Lots of good information on your site, but I have some questions concerning your control panel. In photo 21, what are the silver buttons next to the axis buttons? I've watched the video on operating the control panel, but your hand gets in the way, and I can't really see what you are doing. How about redoing the video so the camera stays focused on the control panel instead of moving to the mill and back. I can hear what the mill is doing. I'd rather see what you're doing. In the upper right corner there are 2 black knobs. It looks like the one on the left is a 3 position switch. Is the one on the right a 2 position? Can you post a full frame photo of both the front and top so I can read the labels? Why didn't you use one of the joy sticks that was in the game controller instead of the one you did use? Did you end up having two USB cables going to your computer? It would appear that you have made more than one of these control panels. Have you given any thought to selling them?
    Sorry about all the questions.
    About the ATC. Did you do any experiments to determine how much pull you actually needed to keep the tool holder from spinning in the collet?
    Thanks for your time and good luck on getting your mill working 100%.
    Bob Hayes
    Chiloquin, OR
  7. #187
    Hey Bob,
    The silver buttons are for feed hold.
    They are holding pushbutton switches wired in parallel with the axis button.
    Below is a high res pic of the panel that shows the 2 knobs on the right
    are the twin joysticks of the Phillips game controller.
    I made my own main joystick for space savings and coolness.
    I've only made the one controller, way too much work to sell them.
    Yes, 2 usb cables to the PC.
    When you open up the Logitech and the Phillips, you can see the switches
    on the circuit boards. I just soldered jumper wires from them to each of the control panel switches.
    Re: power drawbar. From what I've read elsewhere, the spring tension necessary is about 600Lbs.
    Later Hoss
    An alternate email address for me is [email protected].
    Attached Thumbnails Attached Thumbnails control panel progress 110_1500x1125.jpg
  8. #188
    Uh-Oh I see a picture of the controll panel!!!!!
    Hoss,
    You are teasing me, :stickpoke when will you do a post on it???????????????
    Bill
    Bill
  9. #189
    Jul 2003
    281
    Spring Washers
    I was using a STD R8 collet till the one purchase from Tormach came, When I installed the Tormach R8. I found that it was not opening enough to change tools. So what I did was to add one more washer to the four I had, Works perfect now.
    Bob A
    http://www.cad2gcode.com/cncprojects
  10. #190
    Nov 2003
    108
    Great work Hoss and Bob. Nicely done!
    Please let me know if either of you would think this might work...
    If I understand correctly, we need about 1100 lbs to compress the belville springs. The approach you took was to use an air cylinder with about 100 lbs (give or take) plus a lever to bring you up to to the 1100 or so...
    So, I was wondering if a more compact device might be built by using an air cylinder capable of producing the 1100 lbs directly. This cylinder could then squat directly on top of the draw bolt.
    This link shows a cylinder that has a 4 inch bore:
    http://www.poweraire.com/compact-cyl...5_522_548.html
    edit: this link shows a family of these particular cylinders... only up to 2.5", can't find the 4 inch one yet...
    Using Bobs program, a 4 inch bore should result in about about the required 1100 lbs at 100 psi.
    Do you think this might work?
  11. #191
    Jul 2003
    281
    Quote Originally Posted by BeerFizz View Post
    http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=33513154
    This cylinder costs $30 and along with a plate, some bolts and spacers and a valve????
    I'm sure that would work great, but for $3.95 for the used cylinder. It all a matter of the cost of the project. I would prefer the bigger cylinder if cost wasn't the factor. I think the $30.00 price is for the mount not the Cylinder.
  12. #192
    Feb 2005
    149
    how heavy is that 4" bore cylinder? i have a 5" one in my shop but it would be heavy to have sit on my mill which is a X3 so it has a larger head and column...Is it actually 1100lbs or is it less? Some where HOSS mentioned 660lbs or something but not sure if that was the spring or for collet removal
    www.kosracing.com
  13. #193
    Nov 2003
    108
    Hi Koss,
    not sure of the weight or physical size of the cylinder... I'm having trouble getting exact specs. Of course, it may be way to heavy etc. If the required force is 600lbs or so then the cylinder could be smaller... around a 3 inch bore (Bobs program).
    This is the 2.5 inch bore.
    http://www.poweraire.com/series-comp...ore-p-675.html
  14. #194
    Nov 2003
    108
    re. the CQ2 Compact air cylinder.
    http://www.coastpneumatics.com/pdfs/smc/70ASTCCQ2.pdf
    The dimensions are on page 18 of this document. For the 80mm bore device, the height appears to be about 63mm + stroke and about 100mm square. The smallest stroke is 10mm which is plenty.
    Weight is on page 5 and for the 80mm bore with a 10mm stroke plus rod end is about 270+170g ie about 15 oz, which seems very low. Can someone check that?
  15. #195
    Nov 2003
    108
    Quote Originally Posted by Bob Adams View Post
    Hi Bob,
    yes, the original link I posted was the mount. Not easy to find info on this stuff, but it does appear that the 3 inch device (80mm) is n the $70-80 range and the 4 inch device is in the $130 range.
    The 3 inch device should produce about 700lbs at 100 psi and the 4 inch about 1200 lbs. The device itself seems to weigh about 1 pound.
    I'll call the manufacturer in the morning and see if I can confirm this information.
  16. #196
    The LMS Power Drawbar appears to use the same type of air cylinder you've
    been talking about, something with a 2.5 to 3.5 diameter piston.
    It allows them to install the cylinder inside the housing but the housing isn't noticeably
    any smaller than the one I designed.
    They still use a small cam and lever to get 1000 lbs of force.
    The air cylinder is the main component to which everything else is designed around.
    You can spend more (alot) on the cylinder to shrink everything else around it.
    Might explain the cost of their unit.
    To each his own.
    Hoss
    Attached Thumbnails Attached Thumbnails LMS power drawbar.jpg   zbot drawbar.jpg   IMG_1249crop_424x768.jpg
  17. #197
    Nov 2003
    108
    Hoss,
    Please don't get me wrong. What you did is absolutely fantastic. I'm not sure I have the skill set to make all the associated parts and so I was looking at alternatives.
    Today, I spoke (im'd) with the company which sells that cylinder and this is basically what I found:
    The 100 mm device (4 inches) sells for about $124.
    At this price it has:
    10mm stroke
    single rod
    no magnet
    is double acting
    is about 5 inches square and 4 high
    and weighs less than 2lbs.
    According to Bobs program this will generate 1200lbs at 100psi.
    edit: I guess if I get a chance to do this, I would have it squat directly over the bolt with perhaps adjusting nuts for the height.
  18. #198
    Nov 2007
    118
    Hi everyone this is my first post. Yep Im new to the form.
    Ben busy looking over HOSS web site. HOSS Your AWSOME!
    Would like to ask you some qestions if you don't mind me email you?
    Watch your Video's with grate excitment. Your new tool changer Video was realy something.
  19. #199
    Email away Oldboy, I'm glad to help.
    you can email directly to
    [email protected]
  20. #200
    Mar 2003
    103
    How have the spindle bearings been holding up with the added force of the release cylinder?
  1. Hoss ATC Number 3
    By hoss2006 in forum Benchtop Machines
    Last Post: 02-05-2017, 04:47 PM
  2. Hoss's ZX45
    Last Post: 09-06-2012, 03:23 PM
  3. Original Hoss X2
    By baithog in forum Benchtop Machines
    Last Post: 11-21-2011, 02:17 AM
  4. Hoss Mill Console Project
    Last Post: 09-11-2010, 09:45 AM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
