588,219 active members*
3,981 visitors online*
Thread: Hoss's G0704
Page 146 of 344 4696136144145146147148156196246
Results 2,901 to 2,920 of 6871
  1. #2901
    The projects page has most of the important projects I've done listed.
    The calibration one is here.
    http://www.g0704.com/projects2.html#axis
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #2902
    Jun 2011
    695
    Quote Originally Posted by Fastest1 View Post
    You looked thru all 200-300 of his videos? IIRC, he has one as you described. He will pop up with the link in no time. Damn organized guy! I just barely use bookmarks, I can't imagine what his look like.
    I knew he had a bunch but had no idea till I went through them.
    Quote Originally Posted by hoss2006 View Post
    Projects2
    Hoss
    That's the one "Axis Calibration". Could think what it was called.
    Keep them vids coming they are a big help.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  3. #2903
    Jun 2011
    From your earlier post if you click the number in the upper right of the post it will pop open that as a separate window.
    Mcmaster.com has a limited selection of L-belt lengths but sdp-si.com has just about any you'd need.
    Hoss
    As always thanks again Hoss my problem is there's just soo many posts and soo much info here I get brain freeze more often then not......
    Eoin
  4. #2904
    Apr 2007
    101
    I was using the MAD for tool changes for some time but now my right arm has twice the muscle mass than my left as a result so I finally got around to implementing the LD power drawbar which works a treat. :cheers:
    I have a couple of concerns about the quill lock. I found that if I set the PSI greater than 80 on my compressor, the quill gets pushed down no matter how tight I set the lock. Is there any other way to lock the quill in place more securely?
    FYI - I'm using a 3" dia cylinder with 2" stroke only because its what I had on hand along with 3 pairs of stacked bellevilles ()()() set to 80 PSI max. I still get just enough force to release the tool, but I just don't trust the lock, esp given the fact it can drop 2" if it doesn't hold.
    Second question I have is how did you remove the worm shaft from the front? I can't find any retainer rings holding it in place. The diagrams for my CT129N (BF20) doesn't show anything holding it in there either.
    Leo
  5. #2905
    Hey Leo,
    80 psi is only giving you about 550 lbs of force.
    To be able to get more you can tap out the hole for the quill lock (I used 5/16-18)
    and replace it with a bolt or socket screw, I can get it much tighter now.
    If still no joy you could drill a shallow hole in the quill where the lock screw hits it
    so it also acts to pin it.
    The tip of the lock screw turned down below the minor diameter would prevent thread damage.
    There is a pin on the right side of the head to remove so the worm will pull out the front.
    Hoss
  6. #2906
    Apr 2007
    101
    I feel really silly now. I saw what I thought was a PEM threaded insert. Didn't realize it was just a pin.
    Thanks for the tip on the lock. Will do what you suggested.
    So with only 550lbs being able to release the tool holder, that would mean my holding force is too low!
    I used the A-7Q-9-32050 from SDP-SI which are rated at 340 lbs compressed. I just realized my mistake between series and parallel arrangement. I will try them in parallel.
    Do you know how much force the stock bearings can handle?
    Leo
  7. #2907
    Even the smaller upper tapered roller stock bearing has a static load of several thousand pounds.
    Crank as much psi as you can into that 3 inch air cylinder, 125pi would give you close to 900lbs
    which should give enough to open the collet with about 600-700 lbs pull for toolholding.
    Still a small amount but good for light duty work.
    If you come across a 4 inch cylinder sometime it would go with my floating power drawbar with no stress on the bearings.
    http://www.g0704.com/projects2.html#pdb2
    Plans are free for the asking at [email protected].
    Hoss
  8. #2908
    Mar 2012
    189
    Grizzly originally had May 18th for available date, upon placing my order they moved the date to April (Friday the) 13th. I have my DVD fom Hoss, now I need to make room in the shop. Can one of you guys measure from the back of the cabinet to the back of the table when it is all the way to the rear for me? Also how tall is the table top off the floor?
    -Jon
  9. #2909
    Well hopefully friday the 13th will be good luck.
    there's about 4 inches from the table to the rear and about 38 inches from the floor to the top of the table.
    Hoss
  10. #2910
    Mar 2012
    189
    Thanks for the measurements Hoss. Looks like I should be able nestle it next to my Jet 9x20.
    Do I get a merit badge for finally reading all 243 pages of this thread, or do I have to read the original one too?
    -Jon
  11. #2911
    Ahh, you have to read them both and there's a pop quiz afterwards.
    Hoss
  12. #2912
    Mar 2012
    189
    Would it be ill advised to put the x stepper on the left side of the machine like the optima conversion?
    -Jon
  13. #2913
    Mar 2012
    189
    Would it be ill advised to put the x stepper on the left side of the machine like the optima conversion? I am doing a phase 1 conversion.
    -Jon
  14. #2914
    It's personal preference. There's no benefit for one or the other.
    Hoss
  15. #2915
    Here's a sneak peek at what I was working on yesterday on the mill, a new ally bed for my prusa printer to hold
    a 10x10 pane of glass and an ally lower to give more y travel.
    Nothing mounted yet, just laying there for a photo op.
    Milled all the pieces from a 12x12 1/4" ally plate.
    Hoss
    Attached Thumbnails Attached Thumbnails 101_0105_800x600.jpg   101_0110_800x600.jpg
  16. #2916
    Oct 2009
    54
    Hey Hoss,
    Will you be gearing up to sell kits at some point? You have me mighty interested.
  17. #2917
    Jun 2005
    34
  18. #2918
    Jun 2005
    34
    sorry wrong project
  19. #2919
    May 2003
    162
    Hoss, be sure you suspend that heated bed over the ally, I read about a guy that said that the ally sucked all the heat away from the element.
    I'm guessing you knew that...just in case.
  20. #2920
    The PCB is supported on the edges, hopefully enough heat transfers to the aluminum
    to heat the 10x10 glass bed top edges too.
    Hoss
    Attached Thumbnails Attached Thumbnails 101_0113_800x600.jpg   101_0117_800x600.jpg
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
