588,585 active members*
13,576 visitors online*
Results 1 to 5 of 5
    Jun 2007
    3891
    hot off the nm200
    i figured id show some actual work here
    the white thing is HDPE. its a half pattern for a glass mould. it cuts like butter. the curved areas were done with a ball nose at 100ipm with a .005-.008" stepover. the finish is very good, better than i was expecting. the base plate (mould parting board) was hot glued to the table instead of bolted. this was so we could mill the whole surface, as well as not worry about warping under clamping pressure. in hindsight i could have used 1/10 the glue - that stuff holds very well.
    the other part is a vacuum jig for guitar fretboards in aluminium. also turned out rather nice.
    Attached Thumbnails Attached Thumbnails IMG_6120.jpg   IMG_6121.jpg   IMG_6122.jpg   IMG_6123.jpg
    Mar 2009
    163
    Where do you source your HDPE?
    100ipm is a good clip. Do you use an air blast for chip removal?
    Jun 2007
    3891
    Quote Originally Posted by Frogblender View Post
    yeah, intermittently blowing the chips away.
    this block was bought from johnsons in toronto. they dont like cutting off small pieces (this comes in a 4x8 foot sheet) but when you show up in person they seem to let you rummage around the scraps. nice people too.
    Jul 2007
    1602
    If HDPE cuts at all like UHMW no air blast is needed. If you have your feeds and speeds right, you end up with chips that look like mouse turds flying out of the flutes in a steady stream. Quite cool to watch...
    Laird plastics has locations in several major Canadian cities.
    bob
    Jun 2007
    3891
    Quote Originally Posted by rowbare View Post
    bob
    laird is a bit far from me, but yeah, if you need to have it shipped anyway, they are a good one.
    the air blast was only used to move chips out of the way. hdpe builds up a bit of static while cutting, and everything wants to stick to it.
    it does cut and feel similar to uhmw. little waxy shavings, a bit like snow.
  1. Latest Nm200
    By rayoung in forum Novakon
    Last Post: 12-02-2011, 04:30 AM
  2. nm200 under emc2
    By ihavenofish in forum Novakon
    Last Post: 02-21-2011, 08:31 PM
  3. fresh off the nm200
    Last Post: 07-13-2010, 06:31 PM
  4. NM200 V2 soon to ship
    By newton009 in forum Novakon
    Last Post: 07-09-2010, 06:06 PM
  5. Rapids on NM200
    By g29cc in forum Novakon
    Last Post: 07-09-2010, 12:24 PM
