587,997 active members*
2,123 visitors online*
Results 1 to 7 of 7
    Oct 2007
    68
    How to activate Setup Datum on Heidenhain controller
    I follow the Manual on page 68 to activate the Set Datum for iTNC 530 Milling machine with Heidenhain controller but it not work.
    Set Datum button not show on the screen
    Does anyone know other way to activate the set datum please help
    Thank you so much
    Aug 2009
    684
    You should be in manual mode (little hand) or handwheel mode (maybe). Press orange axis letter and 'Set Datum' should appear, or you may have to page through the softkey menus on the edge of the screen.
    DP
    Oct 2007
    68
    I try the orange button but the orange key only select exis for manual or for handwheel don't have room to input number for editing
    and there no set datum on the soft key
    Feb 2009
    48
    In manual mode there is a softkey that says 'set datum' at the bottom of the screen.
    Oct 2007
    68
    In my workshop have 3 Hermle milling machines using Heidenhain controller
    But except 1 machine don't have Set Datum in the manual mode,
    That's why I try to activate the set datum to display/appear in the softkey but it not work,I forgot the error message.
    Feb 2009
    48
    Have you tried scrolling through the soft key menu?
    Oct 2007
    68
    Yes! In manual mode I already using the left and right arrow button to scrolling backward and fordward but there are no "set datum".
  1. Bridgeport heidenhain controller?????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2012, 06:41 AM
  2. Heidenhain 151BQ controller
    By bob S in forum Controller & Computer Solutions
    Last Post: 01-20-2009, 02:28 AM
  3. HEIDENHAIN CONTROLLER
    By alexanderstrand in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2008, 11:28 AM
  4. heidenhain tnc 2500 controller
    By blackpalm in forum Bridgeport / Hardinge Mills
    Last Post: 09-21-2007, 02:20 PM
  5. Chevalier mill with heidenhain controller won't do datum cycle
    By Kavanthony in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-13-2007, 09:52 AM
