587,258 active members*
2,918 visitors online*
Results 1 to 4 of 4
    xfredericox Guest
    Post How to add a flow sensor to a K40
    I have been looking high and low, but cannot find a simple solution to add a flow sensor to my K40.
    This is th flow sensor i got:
    G3/4 Water Flow sensor - Wiki
    Can someone point me to a good and simple solution?
    I rather not involve arduino's and such if possible...
    thanks!
    Nov 2008
    643
    Re: How to add a flow sensor to a K40
    I was able to convert an eBay flow switch for use on a laser.
    NEW! THOMAS PRODUCTS INC. FLOW SWITCH 2100
    Search for the above title.
    It is designed to close a switch at 1.5 gpm. I was able to get it to work on a small water pump by removing its internal spring. So it turns on with any flow. Wire it to your ps on the water sense circuit.
    Other flow switches might also work as long as it's a simple switch.
    Oct 2010
    197
    xfredericox
    for a simple visual aid, to see if water is flowing, I installed something like this
    Attachment 326738
    Kel
    xfredericox Guest
    ok, but what about the sensor I have. Its putting out a pwm signal, and I am looking for some sort of schematic of how to put this in my laser power chain.
  1. Water flow sensor
    By Mcbride19 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-03-2019, 04:34 PM
  2. How to get flow in the tub
    By CaptainVee in forum Mass finishing equipment/media/strategies
    Last Post: 01-17-2012, 09:15 AM
  3. flow jet???
    By axkiker in forum Uncategorised MetalWorking Machines
    Last Post: 12-02-2010, 11:46 PM
  4. flow jet
    By patcareyis in forum Waterjet General Topics
    Last Post: 06-28-2010, 02:37 PM
  5. Flow
    By Haeusser in forum Waterjet General Topics
    Last Post: 03-13-2008, 02:04 PM
