I'd like to add an intermittent air burst, that blows for about 0.7 seconds every 5 seconds of cutting. Ideally, without stopping motion. I imagine I'll use an air control solenoid on a separate feeder hose from my compressor (which also feeds the power drawbar.)
With the Tormach USB I/O board, I could set this up with M codes, except I imagine I'd have to program the M codes manually, and I'd have to figure out where in each G code movement would be the appropriate time. Not great!
I guess there are three questions here:
1) How do I map the post processors "air blast" feature to a particular M code?
2) Could I program the I/O board to do the intermittent bursts for me? Or perhaps hook up some 555 timer monstrosity that is in turn triggered by the USB I/O M-code?
3) Or is there some way to hook into the PathPilot / LinuxCNC setup to generate the appropriate pulses? (I wouldn't need the Tormach I/O for this; I could do my own then, based on an Arduino or Teensy or something.)
I poked around in the PathPilot code a bit, and I found the "schnozz" module which controls the smart-cool; it seems to be a convenient way of learning things I'd like to do. (Also, I'm glad to see that SmartCool uses Dynamixel servomotors, which I've used for several robotics projects!)
But how do I best learn how to add modules to PathPilot? How do I get it to load my module? How do the modules communicate? Is there some hacker's guide or something somewhere?
