587,931 active members*
4,012 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > How big of a stepper for HF 33686 mill
    May 2005
    19
    Question How big of a stepper for HF 33686 mill
    I have a harbor freight 33686 mill that I am in the process of converting. I have a 3 axis hobby cnc driver and 3 steppers from kelinginc.net. The steppers are rated at 304 oz/in unipolar, 425 bi-polar. My power supply is 28V@18 Amps. My ballscrews are all 5mm pitch. Are these steppers going to be strong enough? Do I need to spring for a bi-polar controller? I don't plan on milling anything more than aluminum/brass.
    Link to stepper specs
    http://www.kelinginc.net/KL23H286-20-08B.pdf
    Link to mill specs
    http://www.harborfreight.com/cpi/cta...emnumber=33686
    Jun 2003
    3312
    It depends on what you want to do and how fast. Your steppers should be strong enough for your cuts. You may not get the rapids you want. If you take your supply voltage to 40V you will get better rapids.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Aug 2006
    2758
    I used the same motor on my tests, look at the results here:
    http://www.youtube.com/results?searc...=mardus+kreutz
  1. Need help on mill and Stepper connector
    By RedLabel in forum DIY CNC Router Table Machines
    Last Post: 07-27-2006, 04:57 PM
  2. need stepper mill advice
    By mike10 in forum Stepper Motors / Drives
    Last Post: 08-20-2005, 03:32 AM
  3. Where to begin? Retrofit a Stepper Control to a Mill-Drill?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 05-04-2004, 11:44 PM
  4. My custom stepper box for my Taig mill
    By stokessd in forum Taig Mills / Lathes
    Last Post: 03-23-2004, 08:17 PM
