603,963 active members*
3,124 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How to calculate the voltage for a stepper
Results 1 to 6 of 6
    Feb 2007
    514
    I'm using a Gecko 203v drive on a Nema 23 stepper with the following specifications:
    Rated Current 2.8A/phase
    Resistance 1.1 ohm
    Inductance 3.82mH
    http://web2.automationdirect.com/sta...stepmotors.pdf
    The Gecko drive is rated for up to 80vdc
    How do I figure the best voltage to run?
    John
    Jan 2006
    357
    Amps times phase resistance, So 2.8 x 1.1 = 3.08 volts
    Jun 2003
    3312
    As you go up in the supply ratio to coil voltage you get better high speed performance. I believe gecko recommends three to twenty-five X. So that would put you around 75V max.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jan 2007
    355
    The 3.08 volts is the rated voltage of the motor.
    Gecko recommends running the motor from 4 times (minimum) to 25 times (maximum) the rated voltage.
    My G201 also specifies a minimum power supply of 24 volts.
    In your case, 24 to 75 volts should suffice. The more voltage you use, the more power you'll get. Too much voltage may cause the motor to overheat.
    Don't exceed this motor's rated current of 2.8 amps when configuring the Gecko.
    Although heatsinking for the Gecko is not required under 3 amps, I'd take the safe route and put one on.
    Feb 2007
    514
    Thanks for all the help. BTW, the G203V instructions recommend 4 to 20 times for the power supply voltage. So it looks like a 60 volt power supply is for me.
    John
    Dec 2005
    80
    Hello Big John T
    Remember that most drivers use some form of current limit and so 60V is only fed to the motor for a fraction of a second and then turned on and off repeatedly so the average of ( 60 * Time on/Time off ) will be close to 3V.
    Richard
  1. What voltage for bipolar stepper 2 A, 1 Ohm ?
    By vroemm in forum Stepper Motors / Drives
    Last Post: 01-31-2017, 05:29 PM
  2. Stepper voltage
    By jdholbrook in forum Stepper Motors / Drives
    Last Post: 02-24-2006, 05:06 AM
  3. Stepper / Voltage
    By ckrantz in forum Stepper Motors / Drives
    Last Post: 10-03-2005, 01:02 PM
  4. Stepper motor Voltage
    By metron9 in forum Stepper Motors / Drives
    Last Post: 11-16-2004, 02:10 AM
  5. Stepper voltage
    By glentner in forum CNC Machine Related Electronics
    Last Post: 03-30-2004, 06:02 AM
