603,546 active members*
3,114 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > How can I access the Tool "xoffset" info. / Like I access the Tool Length Offset?
    Jul 2004
    241
    Greetings,
    __________________________________________________ ______________________
    double r = KM.CoordMotion.Interpreter.SetupParams.ToolLengthO ffset;
    double r2 = KM.CoordMotion.Interpreter.SetupParams.xoffset; //This and other new settings, are not exposed to my C# program???
    I tried to do something with the GetTool( but don't really know where to put that in the program? Or if I am executing it properly??
    private void GetTool(index, ref int slot, ref int ID, ref double length, ref double diameter, ref double xoffset, ref double yoffset)
    KM.CoordMotion.Interpreter.SetupParams.GetTool(GV. tool, ref slot, ref ID, ref length, ref diameter, ref xoffset, ref yoffset);
    GV.myslot = slot;
    GV.myid = ID;
    GV.mylength = length;
    GV.mydiameter = diameter;
    GV.myxoffset = xoffset;
    GV.myyoffset = yoffset;
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    May 2006
    4088
    Re: How can I access the Tool "xoffset" info. / Like I access the Tool Length Offset?
    Hi Jeff,
    Sorry you are correct those were not fully exposed. There are some changed files located here to expose them:
    Index of /Software/Patch/ExposeToolTableXYoffsetsV433k
    Replace those files and you should then have ToolXOffset and ToolYOffset properties.
    HTH
    Regards
    TK
    http://dynomotion.com
    Jul 2004
    241
    Tom,
    Thanks so much... I have completed my lathe version... and have it working in 433k.
    This was just a loose end... that will make that portion of the software much easier to manage.
    Thanks again,
  1. Sinumerik 802d sl : message "no access "
    By merhas06 in forum CNC Machining Centers
    Last Post: 01-05-2014, 06:42 AM
  2. Replies: 3
    Last Post: 12-01-2013, 05:21 PM
  3. Setting "Z" tool coordinate in geometry offset
    By Jim Beyer in forum Mori Seiki lathes
    Last Post: 09-07-2012, 12:34 PM
  4. Unable to access tool library V24
    By mgbgt89 in forum BobCad-Cam
    Last Post: 11-23-2011, 03:05 PM
