588,219 active members*
4,143 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > How can I calculate tolerances for metric thread pitch diameter?
Results 1 to 5 of 5
    Jun 2008
    113
    Hello experts
    What's the formula for calculating the max/min pitch diameters for a given metric thread? The tolerance grade is 6g. I've been trying to find a COMPREHENSIVE reference table for thread tolerances but to no avail (a well concealed secret ). Is there any software available for calculating thread max/min/pitch dimensions and tolerances?
    I'd be very thankful for any help.
    Jul 2009
    18
    Smile
    Quote Originally Posted by myhäje View Post
    Hello experts
    hi
    the anser
    Jun 2008
    113
    Quote Originally Posted by agapios View Post
    hi
    the anser
    Thanks but that's not really the answer I'm looking for - no mention of calculating tolerances. Let's take an external M48x3 thread, for example. The maximum pitch diameter is 46.05 and minimum 45.86. How are these values derived?
    Mar 2008
    240
    NUMBER = size of tolerance field. The position of the field in relation to the "Zero" line (Nominal size) is given by a LETTER representing the size of the "base deviation".
    Base deviation is the upper deviation (external) or the lower deviation (internal) thread.
    ______
    I
    I Tol.
    ______
    ------------------Nom. Size
    ______
    I
    I Tol.
    ______
    To designate a thread the tol. number and position are given in reverse i.e. 6g (g6 for shafts etc)
    It gets pretty complicated. So if you really need it get a book.
    Order from "Beuth" in English pocketbook Nr. 45, ISSN 0342-801X English
    ISBN 3-410-11827-6
    Some help is here:http://euler9.tripod.com/bolt-database/22.html
    Metric Fine Thread M48x3
    Pitch dia 4h = 46.051/45.919
    6g = 46.003/45.791
    8g = 46.003/45.668
    Good luck - Juergen
    Jul 2009
    18
    for all that you neet 1 ISO and 1 DIN.
    the DIN 13 for the thread
    and the ISO 286 for the tolerances
  1. How to confire Mach 3 (metric) when my ballscrew 1 inch pitch ?
    By Calico in forum Machines running Mach Software
    Last Post: 12-22-2008, 02:24 PM
  2. Diameter, Pitch, Number of Teeth, etc. on Spur gear?
    By SlimJimmy in forum Waterjet General Topics
    Last Post: 12-04-2008, 05:10 AM
  3. Acme thread tolerances
    By DayneInfo in forum DIY CNC Router Table Machines
    Last Post: 12-30-2006, 07:56 PM
  4. Drawing shaft diameter 8h7 (metric) ???
    By Argofanatic in forum MetalWork Discussion
    Last Post: 12-27-2006, 03:42 PM
  5. Does anyone know the Z-axis pitch of a metric super X-1?
    By digits in forum Benchtop Machines
    Last Post: 11-07-2006, 12:28 AM
