587,482 active members*
2,928 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > How can i change the acceleration on the spindle (Huanyang 2.2kw)?
Results 1 to 9 of 9
    Dec 2008
    441
    Red face How can i change the acceleration on the spindle (Huanyang 2.2kw)?
    Hello.
    What PDxxx do i need to change on, and how is it work?
    I have read in the manual, but i don`t understand it correct..
    Thanks.
    Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Sep 2010
    717
    Do you have a PDF Manual of the VFD in question?
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Dec 2008
    441
    Red face
    Yes
    Attached Files Attached Files
    Sep 2010
    717
    Ok, that's a very bad manual, missing a lot of descriptions...
    There is not mention (that I could find) that says what is the difference btw accel1 - accel4 ..
    So, just try which one works, start from 1.
    Set these:
    PD014 Accel. Time 1 0.1~6500.0S *
    PD015 Decel. Time 1 0.1~6500.0S *
    PD016 Accel. Time 2 0.1~6500.0S *
    PD017 Decel. Time 2 0.1~6500.0S *
    PD018 Accel. Time 3 0.1~6500.0S *
    PD019 Decel. Time 3 0.1~6500.0S *
    PD020 Accel. Time 4 0.1~6500.0S *
    PD021 Decel. Time 4 0.1~6500.0S *
    Hub
    Sep 2010
    717
    And if you use S-Curve:
    PD043 S-Curve Time
    Dec 2008
    441
    Quote Originally Posted by hub View Post
    PD043 S-Curve Time
    Thanks , it work!
    Greetings from Robert.
    Sep 2010
    717
    Quote Originally Posted by Vegabond View Post
    Thanks , it work!
    Glad to hear!
    Dec 2008
    441
    Maby you can take a look at this one too!?
    http://www.cnczone.com/forums/machin...ge_before.html
    Sep 2010
    717
    Sure, I did. But Gerry already answered it correctly I think.
    There is a buffer memory that contains lines of G-code.
    They are already sent to the "controller" with the selected speed.
    It has to process them first I think. Not sure since I don't know the exact way of how it's programmed.
    Also, the step-pulsing is most likely a very high priority processing thread, and the speed change is likely a low one.
    Just guessing here, but that's the most likely reason in my opinion.
  1. Help Help Help - Huanyang VFd and spindle
    By PsychoPig7 in forum Phase Converters
    Last Post: 06-19-2012, 09:54 AM
  2. Spindle Change Over
    By astr in forum Bridgeport / Hardinge Mills
    Last Post: 10-17-2011, 04:46 PM
  3. dx-32 Spindle Acceleration/Deceleration Problem
    By cybermachineman in forum Bridgeport / Hardinge Mills
    Last Post: 05-22-2011, 07:01 AM
  4. X2 and G540 spindle acceleration rate.
    By TXFred in forum Benchtop Machines
    Last Post: 03-03-2011, 01:30 AM
  5. Replies: 11
    Last Post: 01-20-2011, 01:49 AM
