603,924 active members*
3,842 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How can I check a tachometer?
Results 1 to 7 of 7
    Feb 2007
    23
    Red face How can I check a tachometer?
    I have a problem in the lathe CHNC I, I think the problem is in the Tacho
    because when the X servo moves only a few millimetres this one stoped
    and can't put in home mode.
    I checked continuity between terminals and has only 8 ohms
    is normally?
    Dec 2003
    24260
    8 ohms would be around normal, but the way to tell (if DC tach) is to try and turn the motor as fast as possible by hand and see if you get a DC voltage out proportional to speed.
    But normally you either get a runaway condition or tach-loss indication on the drive with tach loss.
    Al.
    Albert E.
    Feb 2007
    23
    I Checked output Voltaje and has 2 DC volts
    I hand moved and have a little voltaje
    do you think that is ok?
    I don't have any information of this tacho
    Dec 2003
    24260
    A common output is around 20v/1000rpm. and anywhere either side.
    If it swings + or - with direction then it is probabally OK but it is best to try it at speed if possible.
    Al.
    Albert E.
    Feb 2007
    23
    The tachometer has 20 v DC with 1000 rpm
    this is good news
    Now I have another problem, I connected the tacho with the motor and have a new alarm. maybe loss the coupling between these components Servo-techo.
    Feb 2007
    23
    the reason was I connected bad the terminals, now is OK! (I Think so)
    the CHNC I has a error:
    Axes Not Enabled
    Axes Drive Fault
    error 6011
    Feb 2007
    23
    did you hear about a problem in Axes Drive Fault?
    the bulb red light turn on when the erros is present
    Have a Nice day
  1. Source for a digital Tachometer for the mini-mill
    By rustyolddo in forum Benchtop Machines
    Last Post: 12-08-2008, 03:41 AM
  2. 120,000rpm tachometer help
    By Smurf208 in forum Hobby Discussion
    Last Post: 06-08-2008, 05:09 PM
  3. I need a Tachometer Harowe or Servo-Tek for CHNC I
    By asantos in forum News Announcements
    Last Post: 02-17-2007, 11:01 PM
  4. Homemade tachometer help
    By Smurf208 in forum CNC Machine Related Electronics
    Last Post: 11-02-2006, 06:39 AM
  5. Tachometer for Spindle
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 03-22-2006, 11:18 PM
