I am was wondering how I can modify a script so that I can get email notification that my job is complete. I am using the mach3 2010 screenset with latest Mach3.
Thanks,
CP
Thanks,
CP
This is a text messaging that works with Verizon (vtext). I would assume you can play with it to get it to work via email. Where is says xxx@xxxx.com put in your email. Where it says xxxxxxxxxx put in your phone number. Where it says xxxxxx put in your email user ID and Password.
'M3030 Macro
Message " MACHINE #549, Process COMPLETED Call Home"
Const cdoSendUsingPickup = 1 'Send message using the local SMTP service pickup directory.
Const cdoSendUsingPort = 2 'Send the message using the network (SMTP over the network).
Const cdoAnonymous = 0 'Do not authenticate
Const cdoBasic = 1 'basic (clear-text) authentication
Const cdoNTLM = 2 'NTLM
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = "Machine Alert"
objMessage.From = """Machine #549"""
objMessage.To = "xxxxxxxxxx@vtext.com"
objMessage.TextBody = "Machine #549 Process Completed.." & vbCRLF & "Thank You(;-)"
'==This section provides the configuration information for the remote SMTP server.
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name or IP of Remote SMTP Server
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "xxx@xxxxx.com"
'Type of authentication, NONE, Basic (Base64 encoded), NTLM
("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
'Your UserID on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendusername") = "xxxxxxxx"
'Your password on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "xxxxxxxx"
'Server port (typically 25)
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
'Use SSL for the connection (False or True)
("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False
'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server)
("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60
objMessage.Configuration.Fields.Update
'==End remote SMTP server configuration section==
objMessage.Send
End
Thanks, that worked great.
