Warco's X2 clone has nothing like 300mm travel last time I looked. If it does, please enlighten me as it would require an elongated base which I would definitely be buying from them. For reference, I'm getting 89mm Y travel out of my ballscrew converted X2, which is a little bit less than the manual machine. It's the no.1 limitation on this machine. I bought mine from Chester.
I strongly recommend the homeshopcnc screws and services. Your best bet would seem to be 5/8" screws on Y and Z, and sourcing a more tricky to find 3/8" ballscrew for the X. If you do go for homeshopcnc, even if you had a lathe, seriously consider his machining service. It is very good value and I can personally confirm machining hardened screws is no fun.
For info, here's a picture of my first anti-backlash solution before I went over to ballscrews. It's a self-cut delrin nut pairing. I got the backlash in the 40-60µm region before friction got too high, but it wouldn't stay that way for long and it isn't the most rigid setup. Ballscrews are in a whole different league.
![](http://pic16.picturetrail.com:80/VOL660/2777486/6910876/160599194.jpg)
