603,964 active members*
1,999 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > how can i measure parallelism of 2 linear slide?
    Mar 2004
    156
    i'm trying to measure parallelism of 2 rails, they are 48" apart. How can i do that?
    Dec 2003
    383
    Hmm that's tricky. How about this...
    Assuming you have two trucks per rail, mount a plate FIRMLY on the "master" rail/truck set, and have the plate overlap and rest upon the two far-side trucks. SHCS the plate only loosely on the far side, so that the plate will drag the slave-rail trucks as it moves. Mount the indicator (0.0005" or better) on the far/slave side of the plate, so that the probe is contacting the rail close to the base. Rails usually have a master edge, denoted by a ground line, measure that edge if you can.
    Secure the master rail firmly against a milled or other precision ledge or edge. Basically, get the master rail straight. In longer lengths, they WON'T be straight, you must make it so when you install it. Secure the slave rail using SHCS and lock washers only tight enough so they will move with some gentle taps of a rubber mallet, or some type of screw arrangement which bears on the rail. Move the plate by hand and note the indicator reading at various points. Work from the center outwards. First, secure the slave rail center bolt relatively firmly. Note the reading. Move to the next bolt hole, make it read the same as the center, secure that one. Reverse direction, go to the next unsecured hole location. Repeat the tightening process from the center outwards. A long rail can easily have significant arc. This procedure should take care of it and create a parallel rail system.
    HTH
  1. THK Slide pack FBW? Cheaper linear system?
    By InspirationTool in forum Linear and Rotary Motion
    Last Post: 05-25-2005, 11:21 PM
  2. T-Slot Linear Slide question
    By audball22386 in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 03-04-2005, 08:19 AM
  3. Simple linear slide design
    By cncadmin in forum Linear and Rotary Motion
    Last Post: 01-19-2005, 10:55 PM
  4. linear slide rods for sale in the Netherlands
    By Tjippy in forum DIY CNC Router Table Machines
    Last Post: 12-06-2004, 08:46 PM
  5. Inexpensive Linear Slide Assemblies?
    By Homl in forum DIY CNC Router Table Machines
    Last Post: 06-03-2004, 07:05 AM
