603,853 active members*
4,144 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How can I ramp off....
Results 1 to 7 of 7
    Jul 2007
    72
    a part feature in an exact mirror of how I ramp on...I have a deep slot that I have to run a .006 radius tool .125 deep in. I have the tool ramping in at a 45 deg angle with comp on...we always have to manually pick ramp points, then need to go in and modify the g code to get the comp to stay on while ramping out...we are using X5 and X9 and er um MC3 yes 3 since that is the only post we currently know how to work, I don't really understand how to modify points in a finished mill contour without messing up the toolpath.
    Any advice or suggestions appreciated.
    CHEERS!
    I'm just a butcher masquerading as a machinist
    Dec 2008
    3216
    You haven't mentioned the slot dimensions or tool size
    2D contour will only RAMP in the Z- direction
    - use a lead in / out
    - can have comp the entire way down, comp turns OFF on the lead out section
    the only ops that may allow Z+ ramping would be circlemill or threadmill ( not entirely sure of the circlemill ) but they also tend be on circles, never tried different geometry yet
    Mar 2005
    988
    Your post will likely need to be modified if you want the comp on before/after Leads (unless your post has a switch for it).
    You could also just draw your ramp on/off lines and toolpath it with your slot...
    It's just a part..... cutter still goes round and round....
    Jul 2007
    72
    We tried drawing the toolpath.. but then finish contour wants to ramp on/off more than once because of the overlapping entities I guess. is there a way to swap the order in lead in/out of the arc/line movement? I want to ramp onto the part feature in a line movement not arc onto it.
    would like arc move above part feature to turn comp on
    ramp at 45 deg onto part feature - entry
    fin contour....overlap entry point
    ramp off at 45 deg - exit
    arc move above slot to turn comp off
    Am I overlooking a toolpath option..or is this a posting issue?
    CHEERS!
    Dec 2008
    3216
    I think we have a "language" problem
    RAMP - to cut in a spiral motion whilst keeping the tool "in the cut"
    LEAD IN / OUT - linear or arc motion to bring the tool "into the cut line", can be used to turn ON or OFF the cutter comp,
    note!! cutter comp on most CNC machine must be taken up while doing a linear move. The linear lead distance must be grreater than the offset size being applied to the tool ( in the machine control registers )
    eg. if using "control comp" the line length must be greater than the tool radius,
    if using wear comp, line has to be greater than zero,
    but, say
    if you need to comp the line 0.100" then the lead in /out liength must be greater than 0.100"--but this is extreme and there are other restrictions ie ( size of internal arcs Vs the tool radius )
    -normally a distance of 0.01"-0.04" or greater would suffice ( it is your choice, shorter is efficient, but you can put larger sizes to suit the situation, same goes for the rad sizes and sweeps )
    this is why the lead in/out has a linear move as it's first and last movement---it is on this feature that comp is adjusted,,,,the arc is to give smooth movement to & from the cutting of the contour wall
    the overlap ( if used ) is to avoid dwell marks on the wall ( -is sometimes used when higher feedrates are applied )
    Never have a tool take-up or cancel comp in a internal corner
    either-
    - break the 1st entity into 2 pieces
    - start at midpoint ( in the Lead in/out tab )
    this can give unexpected NC code results ie no comp cancel move is applied on the operation
    ( some posts need a little biult in error detetion for such a situation )
    Try using a 2D contour,
    -select lead in/out
    -check start at midpoint--ON or OFF ( your choice, depends on the chained geometry )
    - overlap = 0 ( leave OFF unless you need it, complicates other functions from working correctly ie subs, ramping multipasses etc)
    -set line tangent , length 0.01"
    -set arc sweep 45° , radius 0.01"
    copy Left side to Right ( upper middle arrow )
    now, if you are RAMPING a shape,
    use the same settings , now change the contour type pull down from "2D" to "Ramp", and set the options for the angle, pitch or step size
    Jul 2007
    72
    Isnt that ramp definition the description of a helix ramp?
    I need a ramp motion that ramps from say
    (toolpath of ramp is parallel to part feature)
    initial lead in motion of straight line then arc
    ramp on
    x.65 y.10 z.01
    x.65 y.00 z-.05
    machines contour
    then ramps off
    x.65 y.00 z-.05
    x.65 y-.1 z.01
    lead out motion arc then straight line
    When I choose contour ramp in parameter page I get the initial motion I want
    But then it leads out at my final z depth which would destroy part features
    I do break the contour line where the ramping occurs... and I have been using toolpath editor to move my z points but that is a time consuming hassle since it requires Ii change many endpoints z level.
    I still want another option Y the heck wont it ramp off exactly like it ramps on but in reverse.
    Just to help visualize this, we recently milled features with .067" spacing .125" deep using a .006" rad tool @12 deg
    there isnt a ton of space to play with and our tool comp has a fairly small range too.
    CHEERS!
    May 2004
    4519
    Draw in a 3D toolpath of your choosing and use 3D Contour.
    Attached Files Attached Files
  1. Ramp?
    By tsaladyga in forum PTC Pro/Manufacture
    Last Post: 10-31-2013, 12:04 AM
  2. Ramp down outside material
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-04-2011, 12:15 PM
  3. RAMP out on a Pocket
    By Allen123 in forum MetalWork Discussion
    Last Post: 06-12-2009, 06:41 PM
  4. To Ramp or to Plunge?
    By bborb in forum MetalWork Discussion
    Last Post: 01-22-2009, 03:50 PM
  5. Ramp in Z Toolpath
    By solgood in forum BobCad-Cam
    Last Post: 08-15-2006, 04:35 AM
