588,120 active members*
4,662 visitors online*
Results 1 to 4 of 4
    Jan 2011
    9
    How can I support material being cut on my 10W laser CNC?
    Q1. I have a 10W, 10600nm, CO2 Synrad laser that I'm going to try out on my CNC machine. I want to try it out on cardboard and whatever other light material I can find. I have a plywood table on my machine so I need to protect it from the laser. Any suggestions? Ideally with minimal reflections.
    Q2. My test firing of the laser produced quite a lot of smoke. Would a computer fan suffice to clear the area? What stops the cutouts blowing away too?
    I'm minimising expenditure on this until I'm satisfied that everything works.
    Many thanks.
    Quote Originally Posted by Harmonitron View Post
    Many thanks.
    Thin sheet of sand blasted aluminium will do it.
    cheers
    Dave
    Apr 2006
    251
    I make small line breaks in my drawings so the parts are retained in the sheet. 0.6mm will suffice.
    Jan 2011
    9
    OK, chaps. I'll try your suggestions.
    Thanks.
  1. What material for a pet name tag with 40w laser
    By directbears in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-27-2010, 04:53 AM
  2. 0.5 - 1.0mm material for my 60w laser
    By dragehest in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-29-2010, 03:43 AM
  3. Laser coatings on SST material
    By Independent CNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-28-2009, 05:30 PM
  4. ProNest Laser Support Enhancements Resonate with Users
    By Hypertherm in forum News Announcements
    Last Post: 12-15-2008, 04:57 PM
  5. Require material which laser can't cut
    By Kiwi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2008, 07:09 AM
