603,392 active members*
3,631 visitors online*
Results 1 to 5 of 5
    Nov 2012
    How to Change axis direction? help me please.
    I have a Taig CNC mill with a geicko controller running mach 3.
    The x and y move in the correct direction, but the z moves down when it should moves up, and up when it should move down. I've been playing with it for about 2 hours, and have had no luck, searching yielded no results, so please help me, I have cool stuff to be made.
    The Z+ moves the table down, Z- moves the table up. Just need to switch that, but have no clue where to start.
    May 2004
    4519
    Z+ should move the machine so that the tip of a tool is farther away from the table. From your description, it is moving properly and does not need to be changed.
    Mar 2003
    35494
    Config >Homing/Limits and check the "Reverse" column.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2004
    5948
    On a Taig mill, the bed is stationary and the head moves up and down. So the Z axis is indeed running in the wrong direction. I don't have Mach on this computer, but as I recall, to change that you'd go into Config/ports and pins/motor outputs and change the Z axis direction bit from high active to low active (or vice-versa).
    Andrew Werby
    www.computersculpture.com
    Nov 2012
    Thanks guys ill go try it.
    Sent from my PG86100 using Tapatalk 2
  1. A axis direction change?
    By nervis1 in forum Fadal
    Last Post: 10-11-2024, 07:06 PM
  2. Axis on the blink.. direction change issues HELP
    By AndrewBond in forum DIY CNC Router Table Machines
    Last Post: 05-16-2011, 05:50 PM
  3. How to change the direction of cut
    By concombrefrais in forum FeatureCAM CAD/CAM
    Last Post: 07-10-2010, 01:32 PM
  4. Change X Direction on SL-5
    By C-4 in forum Mori Seiki lathes
    Last Post: 06-29-2010, 03:35 AM
  5. x axis ( direction change )
    By musnar in forum HURCO
    Last Post: 10-15-2009, 08:42 AM
