603,940 active members*
2,104 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How To Change Direction on DC Servo?
Page 1 of 2 12
Results 1 to 20 of 33
    Apr 2008
    136
    I have problem with Z axis using Mitsubishi DC Servo
    If I press + sign on panel, the display show the correct direction but the Z axis move to the wrong direction.
    I try to change just the power line to servo motor, the motor vibrates.
    Any suggest which wire should I change if I want make change direction for DC Servo? Should I change the Tach Wire too? How?
    Thanks for your help
    Jan 2007
    333
    What model is the drive?
    Mar 2004
    1527
    My computer doesn't have enough resolution to read your print.
    I've had to do this. You need to switch both the + and - power leads to the servo. And the A and B encoder leads. If you have a differential encoder you need to swap A and A- with B and B-. This is the concept, you'll have to find where on your print.
    karl
    Apr 2008
    136
    Bborb
    The Model is TRA60C. It was an obsolete model of Mitsubishi
    Karl-T
    It seems make sense to swap power line and the encoder. What if I used tacho? which wire should I swap? Sorry I'm rookie for this
    Dec 2003
    24260
    If you swap the armature leads you also would have to swap the tach.
    Then what about your readout direction?
    What CNC control is this? As generally you connect the servo up to the book, and if you need another servo direction or readout reversal, this can be done normally by parameter.
    If you need to reverse the direction of an encoder, you only need to swap A & /A.
    Al.
    Albert E.
    Apr 2008
    136
    Quote Originally Posted by Al_The_Man View Post
    Al.
    I already input the paramater as the list. I got the parameter from the working machine.X and Y are move in correct direction except Z. Readout direction is in correct position.
    The control is MELDAS-83A, I can't find which parameter to reverse direction.
    Is it related with Servo Constant (Parameter code MC)? I try to input with minus value, the servo sound rough and the readout not actual.
    I have no Idea which wire should I swap? The connector from motor consist 5 wire with ground and I'm not sure with tach. The tach code is "PICK UP UNIT" RST-4XC 2V-100RPM.
    Dec 2003
    24260
    The tach appears to be one of the Tamagawa digital tachs, I would not suggest trying to reverse this.
    I am not sure if I have info on the 83A but it might be on the MEAU site.
    Usually it is a parameter that you set to 1 or -1 for either direction.
    Al.
    Albert E.
    Apr 2008
    136
    I thought that was SANYO.what's a matter with tamagawa digital tach, al? It just a resolver isn't it?
    I have search on The MEAU site and they not provide it.
    So... what is the best solution? My problem is I want my Z axis home on the top. Its to dangerous if move the doq to the bottom
    I'm still waiting
    Dec 2003
    24260
    Personally I would not go the hardware change route, all the Mits sytems I have come across are set up by parameter.
    If I get the chance I will see if I can dig out the manual for this system, but It may take a while.
    Al.
    Albert E.
    Apr 2008
    136
    I know I can count on you Al....
    Dec 2003
    24260
    What is the Mits model number on the CNC rack itself?
    Al.
    Albert E.
    Jan 2007
    333
    http://www.meau.com/Files/BNP-A6478.PDF
    But I don't see any other options than physical wiring changes. There are strict polarity relationships between motor, tachometer and resolver/encoder. If the motor leads are reversed then tach wires as well as resolver/encoder wires have to be addressed.
    Apr 2008
    136
    I'm not really sure what model number that you mean.
    I only found :
    MELDAS-83A UM61
    POWER UNIT UX2
    CARD LX61
    CARD LX64
    CARD LX132
    CARD LX59
    I hope this help you much, Al
    Apr 2008
    136
    Thanks Bborb... I already got it from MEAU.
    So..what is the point? Is it safe for me to change the wiring?
    Apr 2008
    136
    Here some pic inside the panel
    Attached Thumbnails Attached Thumbnails Meldas-83A.jpg   2.Meldas-83A.jpg   OKK-MHA400-3.jpg
    Dec 2003
    24260
    It looks very similar to the M1 control UL52.
    Do you have any parameters that show X,Y,Z and the entry is either a 1 or 0, or 1 or -1?
    Al.
    Albert E.
  17. #17
    Apr 2008
    136
    I send it to your email. Please check and let me know if you find somethin new
  18. #18
    Apr 2008
    136
    Do you have M1 parameter description, Al?
  19. #19
    Dec 2003
    24260
    Quote Originally Posted by parametric.ms View Post
    I have for the T1 (Lathe) probably close except just 2 axis.
    not the OP option parameters, however.
    Al.
    Albert E.
  20. #20
    Apr 2008
    136
    Al.
    Now I agree with you. I found on M0 that motor direction is set by parameter.
    My homework is to find where is the parameter on meldas-83A
    I'll try it one by one... wish me luck
Page 1 of 2 12
  1. A axis direction change?
    By nervis1 in forum Fadal
    Last Post: 10-11-2024, 07:06 PM
  2. How do I change autofeed direction?
    By mwalach in forum Mini Lathe
    Last Post: 10-19-2007, 03:11 PM
  3. Replies: 2
    Last Post: 02-27-2007, 05:46 PM
  4. HOW:Line Direction change for MANY lines
    By rherman in forum BobCad-Cam
    Last Post: 09-20-2006, 09:43 PM
  5. How cutting direction change
    By freesman in forum BobCad-Cam
    Last Post: 07-28-2006, 09:02 PM
