Hi
My Thompson bearings are running rough. I`d like to change them. Has anyone installed new bearing in
the aluminum housing. I am wondering how difficult the removable process will be. I will add blocking to the
gantry and brace from the floor to support the machine. There is a 1 foot section of the 1 1/4 support
shafting I can remove to remove the bearings from the machine. One thing I was hoping to remove the bearing
without removing its aluminum support block. Do you think this is possible. I see a dowel pin. This looks like
a problem.
