587,197 active members*
2,711 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > How to chnage Huanyang 2.2KW freq display to RPM
    Feb 2008
    243
    I looked over the manual several times and don't see where RPM can be displayed instead of the ordered FREQ/ And suggestions?
    Dan Mauch
    Jan 2005
    15362
    Re: How to chnage Huanyang 2.2KW freq display to RPM
    Quote Originally Posted by dmauch View Post
    Dan Mauch
    On the Key pad you can toggle between the different read outputs For., Rev., frequency, current, revolutions the led will change for that reading
    Mactec54
  1. Huanyang VFD RPM/Ampere display are not dynamic?
    By Graphicman in forum Spindles / VFD
    Last Post: 01-22-2016, 03:27 PM
  2. Replies: 2
    Last Post: 05-08-2015, 01:02 AM
  3. How is PWM base freq determined?
    By jmc2010 in forum Mach Software (ArtSoft software)
    Last Post: 06-29-2014, 04:05 AM
  4. Morbidelli 504 Freq. Inverter Replacement
    By morbi in forum WoodWorking Topics
    Last Post: 05-27-2013, 09:45 AM
  5. Mach2 PWM freq?
    By Al_The_Man in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2005, 09:05 PM
