603,960 active members*
3,789 visitors online*
Results 1 to 4 of 4
    Jun 2012
    How to Convert 3D Drawing DFX to GCode?
    Hello,
    i have make 3d drawing with autocad / DFX and need to convert it to Gcode
    for my PCIMC-63A / NCStudio 8.76 to execute.
    can anyone help me, which program should i get for make this conversion? and how the method used?
    Attached is my 3d DFX file (generated by my autocad).
    Thank you in advance.
    Regards,
    Paulus
    Attached Files Attached Files
    Jun 2012
    Post Attached the dfx
    Attached the dfx
    tks,
    Paulus
    Mar 2003
    35494
    For something like that, it would be much simpler to just draw a 2D .dxf, with the inside and outside profiles, and use any 2.5D CAM program.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2012
    Smile
    Hello Gerry,
    thank you for your information.
    so does i need to make each of the layer profiles and combine it with 2.5D CAM program?
    what is the name of 2.5D CAM which recommended and name of the function in the program for making the combination?
    sorry if i'm much asking since i'm still newbie in this field.
    thank you very much in advance.
    Regards,
    Paulus
  1. how do I convert a drawing into G code
    By crob09 in forum Uncategorised CAM Discussion
    Last Post: 11-24-2011, 11:03 PM
  2. Convert 3D animation to Gcode
    By druitre in forum Uncategorised CAD Discussion
    Last Post: 09-15-2011, 09:29 AM
  3. 2D drawing convert
    By hitu_vk in forum Uncategorised CAD Discussion
    Last Post: 08-18-2008, 07:04 AM
  4. convert se to gcode
    By ata in forum G-Code Programing
    Last Post: 04-27-2007, 08:06 AM
  5. Convert drawing for use in BobCAD-CAM 2007
    By bobby1 in forum BobCad-Cam
    Last Post: 04-24-2007, 06:10 AM
