603,818 active members*
3,756 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CamSoft Products > how to convert Solidwork 3D draw to DXF file?
Results 1 to 5 of 5
    Nov 2006
    Hi !
    i would very thankful if some one could tell me how to convert a solidworks file to either DXF or g-code
    Jul 2004
    31
    MAke a drawing of your model (in 2D) then save it as a DXF (go to pull down window in the "save as" tool bar). Be sure that your drawing scale is 1:1 or you will have an a shrinken, or enlarged part.
    Jan 2004
    3154
    If you want g-code you will have to buy CAM software or write your code by hand.
    Ditto igor on the DXF thing.
    www.integratedmechanical.ca
    Nov 2006
    thanks Igor!
    but the solidworks file i have now is a 3D model can i convert it to 2D or g-code?
    Jan 2004
    3154
    jmjm
    Igor already splained that.
    Please do the tuturials for creating drawings - seems like you need to
