please give me some suggestion to cut the chipboard without chipping.
Clamping a sacrificial piece of wood to the blowout side of the cut usually helps. Are you cutting with a table/circular saw or a router bit?
-Matt
im cutting with cnc router- 400.00 rpm_/feed rate ratio 7.0. i has used many type of 6mm bit such as single flute, double flute, 4 flute but all my bit was burn when i cut 2-3 pcs double side melamine chipboard 4'x8'.
you can get cutters made for what you need they up, down cut spiral bits.
http://danielscnc.webs.com/
being disabled is not a hindrance it gives you attitude
[SIGPIC][/SIGPIC]
Is that a speed of 400 or 4000rpm? Either way, it's too low.
Try it at a much higher speed i.e. 18000rpm
Regards
Geoff
Use a Compression Spiral.
Vortex Tool: Two Flute Upcut & Downcut Spiral (compression spiral) - Series 3100
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
I have trying 20000, 30000 and 40000 rpm for spindle speed.10000 mm/min for feed rate and 4000 for plunge rate but it make me like ****
get one off the cutters ger21 says to use run about 18000 rpm i have used these cutters they work fine the cut was made at 1500mm/sec 18000 rpm
[SIGPIC][/SIGPIC]
alright dude... i'll try it. my bit just delivered from Australia 6mm Z2 compression spiral bit. hehehe
I'd use a 10-12mm bit, rather than 6mm.
Gerry
