![Quote](images/misc/quote_icon.png)
Originally Posted by
circlecn
It weighs at least 15 lbs. I would love to use it. I would put on a new encoder -I guess- on it. I hooked it up to 24 volts - spun beautifully. How would I go about determining its optimum operating voltage?
Kent
If you hooked up 24vdc I doubt if it would spin if it was brushless, unless you have a BLDC driver amp. If it was straight DC then it was most certainly brushed, two ways of determining voltage required is to estimate the maxium rpm, for a brushed motor, it rarely goes over 3000 unless a specialty.
so you can either apply a voltage and measure the rpm, it will be directly related to speed, so if 24vdc gives you 1000 rpm then it is roughly a 75vdc motor.
Or you can spin it a known rpm and measure the generated DC, and do the same math.
If you need any other specs, I think I have a previous post on finding them emirically.
Al.
Albert E.
