587,278 active members*
3,221 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > how do i determine what size stepper motors to use?
Results 1 to 4 of 4
    Jan 2004
    7
    I just picked up (3) Nema 23 80oz./in. ,6 volt, 5 ohm, 1.2 amp per phase, 1.8 degree, 6 wire, can be wired unipolar or bipolar. what do I look for in a good torque rated stepper motor. I don't have a clue. Thanks.
    Jun 2003
    67
    What do you want to build? Those are low output motors. Perhaps a dremel sized PCB mill/drill could use those. Likely not anything much bigger.
    Jan 2004
    7
    I want to build a small (2' x 2') cnc router. I plan on using these motors with a Xylotec control.
    Dec 2003
    40
    If you used gears and belts, could he gear it down, to say 2:1 and then go with perhaps a laminate trimmer ? Or would it be too slow to move the router ?
    David J. Morrow
  1. Does anyone know of a controller board for synchronized stepper motors
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-04-2005, 05:06 AM
  2. Looking for controller board for synchronized stepper motors
    By Yellowbeard in forum CNC Machine Related Electronics
    Last Post: 04-02-2005, 03:50 PM
  3. Stepper Motors size?
    By mtsrose in forum DIY CNC Router Table Machines
    Last Post: 12-14-2004, 05:21 PM
  4. Stepper Motors
    By kellogs72 in forum Stepper Motors / Drives
    Last Post: 11-30-2004, 02:27 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
