603,371 active members*
3,990 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Shopsabre > how do I extend the soft limit y so I can cut 97" pieces?
Results 1 to 5 of 5
    May 2015
    See title
    Sep 2010
    10
    Re: how do I extend the soft limit y so I can cut 97" pieces?
    Quote Originally Posted by oldcountry View Post
    See title
    That is changed in the wincnc ini file. Make sure your machine will actually make that move without an issue first by turning off the limits on the top toolbar and carefully try the move.
    If you pm me your email, i could help you with it. If you bought the machine new, shopsabre will help you for free. Otherwise your out in the cold.
    Ken
    Apr 2008
    46
    Check L21 in the command reference. It might do what you want and can be placed in the code (with a L20 to turn them back on). I would be very careful about turning these off - could do a lot of damage.
    May 2015
    Thanks man,
    I ended up getting a hold of shop sabre. They told me about the INI. But I found out that myachine was already at its physical limit and changing the soft limit wouldn't help.
    Thanks for your suggestion though.
    Nov 2007
    2466
    already answered
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
  1. RFQ: (2) 1/2" 304L Stainless pieces, approx 5"x4" each piece
    By tsdfab in forum North America RFQ's
    Last Post: 03-24-2013, 04:21 PM
  2. soft limit alarm
    By bigbobr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2012, 04:55 PM
  3. Soft Limit Confusion
    By Deviant in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2011, 09:16 AM
  4. 8055 soft limit question
    By xkadet in forum Fagor Automation
    Last Post: 06-30-2009, 02:46 AM
  5. syil soft limit settings
    By Matty T in forum Syil Products
    Last Post: 03-21-2008, 03:51 PM
