603,546 active members*
3,949 visitors online*
    Sep 2007
    356
    How Do I Load a Program?
    How do I load G Code from Notepad into my Boss 5 memory? I know there must be a command in Notepad that I use to send the code to the Boss, is it Print?
    Nov 2004
    3028
    You need software such as PROCOMM, and the correct cable. There used to be a package of this on EBAY. Communication also enables a very powerful editor.
    George
    Sep 2007
    356
    Thanks George, I ordered a BOB from Hillbilly. When I bought the mill the owner told me he programmed in notepad and then sent the G code to the mill. I couldn't figure out how that worked. Now I can use Mach 3.
    I did get my wiring nightmare figured out, I am running the motor and servos on three phase through a VFD and the controls are running on single phase. Took awhile to get all of the wiring figured out, but I was able to use all of the original controls. Hopefully soon I will be able to make some parts.
  1. FANUC 31i load program
    By Bama in forum Fanuc
    Last Post: 04-18-2010, 09:22 AM
  2. Can't load program to Fanuc 21i-m
    By dpy in forum DNC Problems and Solutions
    Last Post: 04-09-2009, 11:18 AM
  3. Can not load a program via MDI
    By steelhead9 in forum Fanuc
    Last Post: 01-22-2009, 05:31 PM
  4. New user, program won't load.
    By l u k e in forum OneCNC
    Last Post: 11-30-2008, 03:52 PM
  5. Doesnt load all of the program?
    By dafowfidy in forum Mach Mill
    Last Post: 08-07-2008, 02:00 AM
