587,326 active members*
3,054 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > How do I use a dove tool cutter & slot cutter
    Mar 2007
    10
    Hello,
    I have BobCAD 2007 with Level 2 Predator Software. I was wondering how can I use a dove tool cutter and slot cutter using BobCAD 2007? The section, is a recessed arc, that I am trying to cut with these cutters. The part is attached to this message in dxf and dwg formats. Thanks in advance.
    Attached Files Attached Files
    Jan 2006
    4396
    You will use a Full Radius Slot Cutter (AKA Silting Saw). I don't have Level 2 Predator so that is all I can really tell you.
    This place has some nice cutters.
    http://www.mooncutter.com/html/products___catalog.html
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2007
    29
    depth of cut?
    What is the depth of cut you are trying to make?
  1. Bramac - 038 Tool&cutter Grinder
    By CHANDRU in forum Toolgrinding / Toolgrinding Machines
    Last Post: 08-14-2008, 07:36 PM
  2. tool and cutter grinder prgramming!!!
    By brainlessme in forum G-Code Programing
    Last Post: 04-27-2007, 03:57 PM
  3. Walter CNC Tool and Cutter Grinder
    By valexim in forum Employment Opportunity
    Last Post: 01-21-2007, 02:31 AM
  4. Boss 5 Tool Cutter Compensation
    By testertom in forum Bridgeport / Hardinge Mills
    Last Post: 11-06-2006, 11:06 PM
  5. Quorn Tool and Cutter Grinder
    By mtechserv in forum Toolgrinding / Toolgrinding Machines
    Last Post: 10-30-2006, 12:24 AM
