586,042 active members*
3,802 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > HOW DO YOU ADVANCE OKUMA CNC LATHE TAIL STOCK
Results 1 to 16 of 16
    Oct 2018
    101
    Hi there I have an Okuma CNC lathe from 1980s and I don't know how to extend the tailstock on it. I can manually move the entire tailstock but can't extend/advance the tail stock
    can anyone give me some suggestions please? here is a picture of the machine.
    Dec 2008
    3109
    Re: HOW DO YOU ADVANCE OKUMA CNC LATHE TAIL STOCK
    Looks like an older LB15 or 25 ?
    probably OSP5020L control ?
    G & M codes for that era .... so try....
    M55 = Quill Retract
    M56 = Quill Advance
    got this from an OSP 7000L book, also shows the same codes for a P300 control
    Oct 2018
    101
    true but the pedals are supposed to work and they are not working you dig?
    Nov 2005
    196
    There's a screen where you can set it to use the tail stock. It's the same screen that you set ID or OD chucking. I can't remember if it's under settings or parameters. If you can't find it then I can send you more info when I'm at work tomorrow morning.
    Oct 2018
    101
    Quote Originally Posted by Technical Ted View Post
    ok thanks I think you're referring to chuck work?? that should be on "1"?
    Dec 2008
    3109
    Maybe a broken wire to the pedals....
    use the check data page to see if the pedal press is being acknowledged.
    Nov 2005
    196
    Quote Originally Posted by okuma1984 View Post
    That is correct. If it still doesn't work then go to the back of the machine & turn up the tail stock pressure. There's times on our LB 15 that we have to give the tail stock a good whack before the quill will extend. Let us know how you make out.
    Oct 2018
    101
    you are absolutely correct thanks a lot the chuck pressure was too low.
    Oct 2018
    101
    how you doing, genius
    got a problem and hopefully you have a solution for me?
    I noticed I couldn't turn on the spindle anymore (I could single jog it) but I had to turn off what I originally turned on to advance the tail stock eh?
    so what's the deal with this machine? how does this work?? tail stock has to be off before the spindle can start spinning?
    Jun 2015
    4154
    hy
    moving the tailstock requires 0 rpm and turret at upper limit (XA+soft limit); both conditions may be ignored by an optional intelock, if available for your machine
    try M157 ( also optional maybe ) ... i don't have experience with your machine, so i can't give you exact infos / kindly
    Oct 2018
    101
    Quote Originally Posted by deadlykitten View Post
    hy
    yeah
    your input was not recognized
    what are you talking about
    Nov 2005
    196
    Once the tailstock is activated it has to used (advanced) to run a program. Kind of like trying to run a program without a part in the chuck. As Deadly mentioned there are M codes that can be used to get around that. You would need to use those codes if you wanted to center drill a part & then use the tailstock.
    M156 - Center work interlock off
    M157 - Center work interlock on
    M55 - Tailstock retract
    M56 - Tailstock advance
    Oct 2018
    101
    Once the tailstock is activated it has to used (advanced) ..
    sorry it has to what?
    Dec 2008
    3109
    if you activate the tailstock
    ... it has to have the advanced acknowedge limit switch conformed (or made) before you can run in full auto.
    Nov 2005
    196
    it has to be used
    Oct 2018
    101
    got it
    thanks
  1. Replies: 0
    Last Post: 09-06-2015, 03:18 PM
  2. tail stock for okuma lb35
    By weifa81 in forum Okuma
    Last Post: 06-16-2013, 11:49 PM
  3. Tail-stock DRO for Mini Lathe
    By GeorgeRace in forum Mini Lathe
    Last Post: 02-19-2011, 06:13 PM
  4. Tail stock wont Advance
    By Jedi in forum MetalWork Discussion
    Last Post: 11-16-2006, 02:20 AM
