603,935 active members*
4,591 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How does a servo hold its position?
    Feb 2004
    2337
    I have just taken delivery of my servos and am wondering how the servos hold their position.
    There are just two wires that drive the servo, and all the encoder wires. I can understand how with the 2 drive wires you can forward and reverese the servo but how does it actually hold its position electrically. My only theory is that the driver will pulse the servo back and forth rapidly to hold the position. Is this correct?
    I am doubting this theory because I can imagine that would make the servos vibrate, therefore causeing a jagged movement on the whole machine.
    Does any one have an electrical explanation?
    Dec 2003
    24260
    Benny, Simply put the control reads any servoing error by virtue of the encoder feedback and sends the appropriate correction signal, whether or not the servo 'vibrates' or is slow responding is all to do with the system/amplifier tuning. When the tuning is correct, the following error is at a minimum, over correction or too much gain in the system causes oscillation. Some sophisticated software systems have a built in oscilloscope screen whereby you can visually tune the servo's.
    Al
  1. What is a Servo ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 07-16-2005, 07:29 AM
  2. Servo Motor Running away.
    By murphy625 in forum CamSoft Products
    Last Post: 02-27-2005, 08:08 PM
  3. Progress on my servo controller
    By arvidb in forum CNC Machine Related Electronics
    Last Post: 01-24-2005, 04:14 PM
  4. Servo position errors w/FC
    By Swede in forum FlashCut CNC
    Last Post: 05-29-2004, 11:17 PM
  5. steppers or servo drives
    By mmjpotter in forum Gecko Drives
    Last Post: 03-30-2004, 09:56 PM
