587,997 active members*
2,156 visitors online*
    Apr 2007
    13
    How to Dreep Feed On Fanuc 9?
    anyone knows how to drip feed on fanuc 9?
    parameter setting,card option,etc?
    thank's a lot
    Sep 2010
    1230
    Quote Originally Posted by Rizaldewa View Post
    thank's a lot
    The following parameters have to be set at the control and a cable configured as shown, made or bought. The cable is simple to make; use shielded cable having at least 3 wires.
    Your control should have a TAPE mode. You use this mode when drip feeding (DNC) to the control. The PC software usually has a DNC mode as opposed to just Send Mode. Get the PC side ready to DNC, select TAPE mode at the control and press cycle start to run the program. All functions such as Optional Stop, Single Block, Feed Hold, Block Delete ect, all work as per normal. The only limitation is that if the program uses Sub Programs, the Subs have to be registered in the memory of the control.
    Regards,
    Bill
    Parameters
    311 = 10 (4800 Baud Rate) Starting Point
    340 = 2 Input Device
    341 = 2 Output Device
    Control Set Page Settings
    I/O = 1
    ISO Format = 1
    Cable pin out for Xon Xoff handshake
    Machine End--------------------PC End
    DB25 Male Connector----------DB25 Female-------DB9 Female
    1 (Chassis ground)--------- (Not connected)--- (Not connected)
    2--------------------------------3-------------------2
    3--------------------------------2-------------------3
    7--------------------------------7-------------------5
    4 and 5 bridged
    6,8,20 bridged
    PC software settings
    Handshake Method = Xon Xoff
    Baud Rate = 4800 (Starting Point)
    Data Bits = 7
    Stop Bits = 2
    Parity Bit = Even
    Apr 2007
    13
    Many thank's Mr. Bill,it is very useful
    good luck!
    regards
    Rizal
  1. FANUC 3M DREP FEED
    By renato13 in forum Fanuc
    Last Post: 01-22-2023, 12:05 AM
  2. Fanuc 10M - Drip Feed
    By Swemill in forum Fanuc
    Last Post: 05-03-2017, 12:51 AM
  3. fanuc o-t feed rate help
    By joe1970 in forum G-Code Programing
    Last Post: 08-29-2009, 05:49 PM
  4. Replies: 13
    Last Post: 01-03-2009, 05:44 PM
  5. Fanuc 6mb drip feed
    By cowleym in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2008, 11:25 PM
