603,377 active members*
3,043 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Jan 2006
    4396
    Quote Originally Posted by cadcam View Post
    I have used Ball Em to the 60deg spade shown in the links from Cutting molds to parts to prototyp stuff. there are allot of good thoughts here.
    if you don't know the proper way to do it this is an issue. but other wise not a true statement.
    Here is a few thinks from the last year and the Mirror plaque from my old show car from 10 years ago.
    Also if you want some mastercam basics for engraving use my link in my sig and at the bottom of the page there is a button called Engraving.
    X3 LOOKS NICE!!!!!!!!!
    I scoped out the 4th Axis Engraving Video, and you make it look easy, and the Options, NICE!!!!!!!!!!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  2. #22
    Jul 2008
    5
    ENGRAVING TOOLS
    I have even used a #1 or#2 center drill in non-ferris metals. It cuts very nicely and with small depth of cut it will perform for a long time. I usally use this on lettering, although it will work in some countouring applications where hentracking design is wanted. My next choice is a small ball endmill for contour engraving. And of course the standard 1 flute engraving tool. Much care is needed in lettering with this. It will last far longer if a small radius is on the tip. Good luck. bradmancue
  3. #23
    Apr 2003
    3578
    Tom, you any were near Crissair up there in AV? I was up there last sat doing some trainning as I see you are local.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  4. #24
    Mar 2008
    377
    hi again do you guys know if the engraving tools have a 3/8 shank thats because all I can fit on my mill are 3/8 diameter ,
  5. #25
    Mar 2008
    377
    Quote Originally Posted by tobyaxis View Post
    where do can you get this x3 videos
  6. #26
    Apr 2003
    3578
    Under my Sig sir. the last link and then go to the bottom to the buttons.
    Cadcam
  7. #27
    Sep 2008
    8
    Engraving
    We use a #1, or #0 center drill spinning as fast as you can with a feedrate of F20. and a depth of .005 to .010
  8. #28
    May 2007
    71
    thanks
Page 2 of 2 12
  1. WHAT THE BEST METAL TO ENGRAVE IN?
    By hillco148 in forum MetalWork Discussion
    Last Post: 07-15-2008, 08:45 AM
  2. How to engrave pcb with laser
    By codes in forum Uncategorised MetalWorking Machines
    Last Post: 03-17-2008, 09:23 PM
  3. What is Grade Engrave?
    By SkipW in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-23-2007, 10:10 PM
  4. Need to engrave on a sphere
    By carbidecraters in forum BobCad-Cam
    Last Post: 07-29-2006, 02:02 PM
  5. Desk Engrave
    By WOODKNACK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-25-2005, 05:19 PM
