I picked this vise up cheap thinking I could fix it and make it workable. The question is, what is the best way?
1) Remove the broken pieces and build it back up with weld (nickel rod, PITA), mill and grind back to good.
2) Put it back together and let the bolts/clamping force hold the load.
3) Mill a new slot in from the existing and redrill for bolts. I would end up with a little shorter vise but it might be the easiest (best) way.
Any ideas?
Matt
