603,379 active members*
3,644 visitors online*
Results 1 to 4 of 4
    Mar 2016
    3
    How to flatten DXF file
    I have the files to build a 4th axis that are in DXF format.. V carve Pro 8.5 cannot open them. Contacted Vectric and they said the files needed to be flattened. Being new to all this unsure how to accomplish this. I do not have any software that will do this. I will attach the file and if someone could do that I would be grateful. If you can correct the file you may send them to my pm [email protected].
    Feb 2016
    6
    Re: How to flatten DXF file
    Save ur dxf file in old autocad version like dxf 2004.
    Sent from my SM-G935F using Tapatalk
    Dec 2013
    5720
    Try this attached file
    Feb 2016
    6
    Ok tomorow m not on pc now.
  1. Replies: 13
    Last Post: 12-30-2014, 06:34 AM
  2. Replies: 2
    Last Post: 12-12-2010, 12:45 AM
  3. Using fly cutter vs End mill end for flatten material
    By Micro Milling in forum MetalWork Discussion
    Last Post: 04-01-2010, 01:07 AM
  4. Best end mill to flatten steel
    Last Post: 12-10-2009, 07:09 PM
  5. Flatten/Squash G-code to constant Z
    By 94vette in forum G-Code Programing
    Last Post: 05-20-2008, 06:42 PM
